Modifying Stock Sway Bars
Old Mar 21, 2003 | 08:16 PM
LudeyKrus's Avatar
Default Modifying Stock Sway Bars
I have been looking at modifying my lude in cheap ways, and I thought about this: instead of shelling out $200+ for a good set of sway bars to improve my handling, I was considering pulling my rear sway bar, welding more material on it to make it thicker, and then grinding/adding to make the handling more neutral. Any ideas or comments before I start?
Old Mar 21, 2003 | 09:04 PM
Honda318dx's Avatar
Default Re: Modifying Stock Sway Bars (LudeyKrus)
just get a ST rear swaybar, you don't need a front one.. 125$ from http://www.nopionline.com
Save yourself wasted time and aggrivation
Old Mar 21, 2003 | 10:12 PM
Que_Lude's Avatar
Default Re: Modifying Stock Sway Bars (Honda318dx)
Thanks for the info
Old Mar 22, 2003 | 06:29 AM
DirtyLude's Avatar
Default Re: Modifying Stock Sway Bars (Que_Lude)
The sway bar is spring steel. You can't weld it without changing it's elastic properties. Just get an ST bar.
Old Mar 22, 2003 | 08:15 AM
LudeyKrus's Avatar
Default Re: Modifying Stock Sway Bars (DirtyLude)
I have all the time and aggrevation in the world! But....
You have a point there...should of thought about that. I'll have to look into that more.
Old Mar 22, 2003 | 09:52 AM
1fast5gp's Avatar
you can go with a nuespeed too.. i like mines alot
Old Mar 22, 2003 | 11:03 AM
sslude's Avatar
Default Re: Modifying Stock Sway Bars (1fast5gp)
so you guys are saying with just the rear sway, it will be better than just getting the set? or is that becuase if you only get the rear than you'll get more oversteer and that prolly what you want on an FWD right?
Old Mar 22, 2003 | 10:16 PM
Honda318dx's Avatar
Default Re: Modifying Stock Sway Bars (sslude)
exactly!!
Old Mar 25, 2003 | 07:16 PM
LudeyKrus's Avatar
I know, back from the dead, but...
Who has only the rear swaybar? Is the oversteer very strong, or does it give a nice neutral feel? How does it compare w/ the full set of swaybars?
Old Mar 25, 2003 | 09:16 PM
Honda318dx's Avatar
neutral feeling.. nopi sells them seperatly..
royalrebel
Suspension & Brakes
11
Dec 19, 2008 07:19 PM
drmwgn
Honda Fit
Dec 7, 2007 07:50 AM
DarkBB4
Feb 1, 2006 01:16 PM
MaaseyRacer
Aug 17, 2004 09:40 PM
Jordan_4WS
Feb 22, 2002 12:41 AM
