Audi A4 HID Retrofit
Old Mar 21, 2003 | 08:04 PM
oxSLEEPERxo's Avatar
Default Audi A4 HID Retrofit
I just wanted to ask where did you guys put your ballast, for those of you who used the Audi a4 HIDs. I've read skafia's tutorial, but he used the ballast from the A6 which had longers harness. I just want some ideas before I start hacking up my headlights.
many thanks
[Modified by oxSLEEPERxo, 12:05 AM 3/22/2003]
Old Mar 21, 2003 | 11:38 PM
skafia's Avatar
25 Year Member
Default Re: Audi A4 HID Retrofit (oxSLEEPERxo)
? You mean the wires leading to the bulbs from the ballasts where longer?
You can extend them easily. Just make sure you solder it up pretty well.
I placed one ballast underneath the ABS bracket, and the other somewhere on the other side, I forget. A very good place for the right ballast is underneath your fender, there's holes to mount a bracket. That's where I'm putting the right one when I replace my projector in a few weeks.
Old Mar 21, 2003 | 11:44 PM
uNF$@#!'s Avatar
Default Re: Audi A4 HID Retrofit (skafia)
i would not suggest using solder to attach HID components together.
voltage may be low, but current is another story.
i'd actually suggest crimping them instead.
Old Mar 22, 2003 | 06:12 AM
Default Re: Audi A4 HID Retrofit (Dave-ROR)
Thanks Guys. I knew the Arrr owners will come through!!!!!!!!
Old Mar 22, 2003 | 07:13 AM
Padawan's Avatar
Darth ModerVader
voltage may be low,
Not at start-up.
Old Mar 22, 2003 | 10:28 AM
skafia's Avatar
25 Year Member
Why would solder be a bad thing?
kriptik
Apr 19, 2005 07:48 PM
kriptik
Mar 9, 2005 02:39 PM
billyhoe
Oct 16, 2004 10:49 PM
integramic
Sep 9, 2004 12:21 AM
RallyRedGT-V6
Jul 27, 2004 02:46 PM
