What size is my HF sway bar?
Old Mar 21, 2003 | 06:51 PM
wadafa's Avatar
Default What size is my HF sway bar?
Anyone know what size the front sway bar on an '88 HF is?
thanks
Old Mar 21, 2003 | 07:01 PM
FourthGenHatch's Avatar
Default Re: What size is my HF sway bar?
Are you sure they even have one?
Old Mar 21, 2003 | 07:09 PM
wadafa's Avatar
Default Re: What size is my HF sway bar? (FourthGenHatch)
yeah they do, just lazy to measure it right now
Old Mar 21, 2003 | 07:20 PM
zCivic's Avatar
Default Re: What size is my HF sway bar? (wadafa)
HF/STD didn't come with sway bars..DX came with front only and SI's had front and rears...Unless somebody has added them you dont have one or you dont have a HF....
Old Mar 21, 2003 | 08:06 PM
wadafa's Avatar
Default Re: What size is my HF sway bar? (zCivic)
HF's came with only the front,
Old Mar 21, 2003 | 08:43 PM
turbohf's Avatar
i have a 88 HF, it has a front bar too. im also curious of the size...
Old Mar 21, 2003 | 08:48 PM
the DR.'s Avatar
Default Re: What size is my HF sway bar? (turbohf)
pretty sure the HF did come with a sway bar, pretty sure it was a toothpick though.. i'd like to say 13mm off the top of my head, not sure though.. there is a post in the archives with the size, but i cant seem to find it
Old Mar 21, 2003 | 11:04 PM
CRX Si's Avatar
Default Re: What size is my HF sway bar? (SlicedBread)
i think 13mm is way small, i wanna say 19mm or is that the SI's
[Modified by CRX Si, 3:05 AM 3/22/2003]
Old Mar 22, 2003 | 04:19 AM
zCivic's Avatar
Default Re: What size is my HF sway bar? (CRX Si)
OK a STD didn't even come with a sway bar and that is most comparable to the HF minus the MPFI....
Old Mar 22, 2003 | 07:17 AM
slowman's Avatar
I took way too long
19mm is way too big sounding i think. 13mm is more like it, have you ever looked at the tooth picks they call "sway bars"? so small
[Modified by crunk'd, 11:17 AM 3/22/2003]
Old Mar 22, 2003 | 11:40 AM
CRX Si's Avatar
Default Re: What size is my HF sway bar? (crunk'd)
i think i am getting it confused with the Si's...
Old Mar 22, 2003 | 11:49 AM
civicwagonman's Avatar
its about 2mm smaller than the si one. my 88 and 89 hf both came with sway bars.
Old Mar 22, 2003 | 05:19 PM
the DR.'s Avatar
Default Re: What size is my HF sway bar? (civicwagonman)
an si one should be 18mm..
Old Mar 22, 2003 | 07:06 PM
wadafa's Avatar
18 - 2= 16, so 16 mm then??
i'll check tomorrow and let you know
Old Mar 22, 2003 | 08:16 PM
One of the best buys I ever got was a Caliper tool at the cheapy store for $.99. I use that bastard to measure all kinds of crap.
Old Nov 17, 2020 | 04:10 PM
Tyson's Avatar
HF 17.2mm "G"
front. the letter is painted in the middle of the swaybar and embossed on the side of the bushing.
F = 19mm solid - all 4 door civics and wagon
G = 17.2mm hollow - CRX HF (Civic STD had no front swaybar)
H = 18mm solid - 3dr Civic/CRX DX, Si
K = 23mm hollow - DA integra
rear. the number is embossed on the side of the bushing. I believe they are all solid.
13.0mm = 3dr Civic Si
15.0mm = CRX Si
14.7mm = 3dr DA integra (doesnt fit EF perfectly, see explanation below)
15.9mm = 4dr DA integra (doesnt fit EF perfectly, see explanation below)
16.0mm = JDM SiR / EDM VTi CRX w/ B16 (uses a 15.9mm bushing)
Old Dec 12, 2020 | 03:12 PM
stankewj's Avatar
Originally Posted by Tyson
HF 17.2mm "G"
15.0mm = CRX Si
Few questions;
Is G = 17.2mm hollow - CRX HF for the 1990 Hf as well?
Is there a picture available of this part (separate and installed)?
Any leads on finding one (assuming this is the part I am missing)?
Lug nuts let loose on a barn find and wheel separated from hub, lower driver's ball joint snapped while dragging, left drive shaft broke, and a hollow tube bent under the driver's side firewall
After replacing lower ball joint, car rolls and steers, Still need to replace the drive axle and whatever tube bent / broke.
Old Dec 12, 2020 | 07:50 PM
Tyson's Avatar
Sway bar sizes are the same for each model for all years.
Old Dec 14, 2020 | 06:18 AM
TacoCat's Avatar
5 Year Member
The HF has a 17.2mm hollow bar while the DX and SI have a solid 18mm bar. While the front sway bars are interchangeable, they are not the same spring rate. Unless you plan on racing the car, it likely won't matter much if you use a 18mm solid bar from a DX or SI.
JDMGSRCRX
Oct 16, 2014 11:12 AM
japrex
Nov 29, 2004 04:49 PM
Lo-Buck EF
28
May 18, 2004 03:20 PM
phan
Feb 24, 2004 06:24 AM
