sunroof switxh
Old Mar 21, 2003 | 03:52 PM
982drLS's Avatar
Default sunroof switxh
i have a 98 Ls, when i open my sunroof it opens fine, but when i hit the switch to close it, it pretty much stopped working now.. i use to have to push a few times then it would go, now it only opens, then i have to press if like 20 times for it to close... anyone else had this problem? or know how to fix it? matbe where to get a used sunroof switch from? Thanks
Old Mar 21, 2003 | 06:46 PM
tC_Dragon's Avatar
Default Re: sunroof switxh (982drLS)
you can pick up a used one from any salvage yard... but i suggest you take apart your first and check for any loose or frayed wiring. Perhaps its something realtively simple like that. who knows....
Old Mar 21, 2003 | 09:58 PM
Brian-Brian
Guest
Posts: n/a
aye mines was like that too but i spray some wd40 and it works good.....
probably some rust stuck that's why it's hard to closed so use some wd40....
Old Mar 22, 2003 | 12:42 AM
GSRaCeRbOI's Avatar
try some electrical contact cleaner for the switch and check the wiring... for the sunroof.. clean the tracks/rails w/ WD-40.. then wipe it clean and use white lithium grease to lube the tracks.. start the car (so u don't kill the battery) and open and close it like 10 times...
I did this on my car and the sunroof is smooth as silk... before it was annoying as hell as it would slow.. then the alarms sunroof/window closure module would think the sunroof was closed when it wasn't because of the resistance/current draw from the slow/stuck sunroof...
Old Mar 22, 2003 | 02:23 AM
kappa's Avatar
i would suggest taking the switch apart first; it's fairly simple. there is one screw i believe that holds it in, along w/ some wires, so be careful when extracting it. pop off the switch cover and see if there are any noticable problems. put it back together and give it a go. if it works ... then your home free ... if it doesn't ... buy a new one i guess
Old Mar 23, 2003 | 08:28 AM
982drLS's Avatar
Default Re: sunroof switxh (kappa)
right on, thanks for the suggestions, im gonna take the switch out and try cleaning it, im guessing its just dirty, cause it opens everytime like a champ, but when i close it the switch doesn't wanna work unless i push it 20 times
Edul59
Sep 30, 2011 01:49 PM
Hondasalesman
Mar 27, 2009 09:11 AM
rexdriver88
Aug 28, 2004 10:34 PM
AlpineCRX
Apr 17, 2003 08:14 AM
B16CRXhybrid
Jul 14, 2002 09:41 AM
