ball joint on crx????
Old Mar 21, 2003 | 01:37 PM
VisualEcstasy's Avatar
Default ball joint on crx????
how in the hell do you get the ball joint to stop spinning when tryin to put the castle nut back on it???? damn thing just sits there and spins. i have a jack under the lca, had a friend stand on the hub while i put a c-clamp on the top of the joint and the bottom of the lca, so that it would be pressed all the way together but this sumbich wont stop spinning. anyone got any pointers?????
Old Mar 21, 2003 | 01:50 PM
HybridFiend's Avatar
Default Re: ball joint on crx???? (BurntRice009)
There are some things that the require an impact wrench, this is one of them!
Old Mar 21, 2003 | 04:13 PM
SiR Kid's Avatar
New User
You can put a jack under the control arm, and jack the spindle up some. That will put the ball joint under a load and keep it from spinning.
89efhatchcrap
Suspension & Brakes
24
Feb 17, 2009 10:36 AM
chibiko
Jun 6, 2007 08:45 PM
innes887
Apr 12, 2007 04:03 PM
azian21485
May 2, 2005 05:48 PM
Vp Special K
17
Jan 6, 2004 02:08 PM
