How do i test my distributer... DOHC external coil..
Old Mar 21, 2003 | 12:49 PM
BoostedH23a1's Avatar
Default How do i test my distributer... DOHC external coil..
well my fcukin car willnt start have a check engine light on and my jumper will not flash it.. im thinking its the distrib.. how do i test it.. its one from a 94 DOHC H23 prelude.. same as the H22 distrib.. thanks
Old Mar 21, 2003 | 12:53 PM
dfoxengr's Avatar
Default Re: How do i test my distributer... DOHC external coil.. (BoostedH23a1)
does it crank at all? if so pull a spark plug and ground it and check that way, if theres a spark its ok if not ur screwed, make sure the wires ur using work though, that could then be another problem.
Old Mar 21, 2003 | 12:56 PM
Default Re: How do i test my distributer... DOHC external coil.. (hybridvteceg)
no injector pulse and no spark... im thinking its the distrib cause it runns of the cam sensor and crank sensor for all that i belive
Old Mar 21, 2003 | 01:08 PM
dfoxengr's Avatar
huh? the dist is turned by the cam
Old Mar 21, 2003 | 01:09 PM
yea i know its turned but the cam.. u get spark and inj pulse throught the cam and crank sensor though which are in the dist.
Jeremy Harris
21
May 2, 2016 10:58 AM
phj
Honda Civic (2001 - 2005)
15
Jun 16, 2011 04:43 PM
ZRose
Jun 20, 2009 10:27 AM
spettinger
Jul 15, 2005 03:09 PM
mhgleitz
Oct 25, 2003 02:34 PM
