driver side harness
i need some help linking up my zc into my 89 crx dx how do i link it up on the driver side i have the comlplete wiring harness that belongs to the zc engine. (can i use any 88-91 mpfi harness or do i use an 86-89 acura harness) your help would be appreciated thanx
you can use the DX harness just add wires, or a 88-91 SI harness will also work. ZC may work if you still have it. just need to add the wires from the ECU upto the connectors.
thanks zcivic but what i meant was that on the driver side there is a plug that looks like the harness on the oppisite side but it doesnot match with the zc connection i think this is where the resistor box goes or plugs into check it out and help if u can thanx
The DX harness will NOT mate with the ZC harness. Here:
http://hybrid2.honda-perf.org/tech/4gdxtozc.html
Basically you will use BOTH harnesses, the stock DX harness will basically stay in place, you will be adding in the MPFI (injector setup) portion of the ZC/A6 Harness, lots of sites show how to do the DPFI-MPFI swap,
Good luck.
Jeff
Good luck.
Jeff
Yup what AbaZ said. Just use your existing DX harness, and add the wires you need from your ZC harness. When we did my MPFI, I used B16A1 injector wiring. It's all the same.
88crxdxfastwhip
Nov 3, 2005 06:46 AM
D3U1LT
Jun 27, 2005 01:18 PM
