changing transmission fluid
The only difficult part is filling it up again, but it's not bad if you have a funnel with a long spout or a hand pump (that's what I use). C-speed is pretty good with their how-to's:
http://www.c-speedracing.com/howto/t...transfluid.php
Changing tranny oil is pretty easy. If you can change your car oil, you can change tranny oil. Tranny holds about 2.6 quarts so purchase three quarts of tranny fluid and your're good to go. HERE is another DIY article for you. HTH
[Modified by Eva01, 3:19 PM 3/21/2003]
Hardest part is loosening the FILL bolt from the case.
Make sure you loosen BOTH bolts (fill/drain) before you drain the oil so you know you can refill it.
It is not a hard job though.
(Get both crush washers from acura too)
db8sirg
Feb 18, 2004 06:04 AM
professorman
Jan 12, 2003 06:40 AM
