All b-series oil pans compatible?
Old Mar 21, 2003 | 01:19 AM
yellow blur's Avatar
Default All b-series oil pans compatible?
B16/B18 maybe even B20 pans are compatible with eachother? Interchangable? Thanks guys.
edit: wanted to specify, are the b16/b18c and or b18b/b20 pans able to work in place of an ITR oil pan?
Ed
[Modified by yellow blur, 2:38 AM 3/21/2003]
Old Mar 21, 2003 | 08:50 AM
Default Re: All b-series oil pans compatible? (yellow blur)
anyone know?
Old Mar 21, 2003 | 08:57 AM
dfoxengr's Avatar
gsr pan and windage tray will work instead of R.
b16 wont if im correct
Old Mar 21, 2003 | 09:36 AM
Default Re: All b-series oil pans compatible? (hybridvteceg)
In other words, swapping the gsr pan ONTO my R would be a bolt on, no need to change pickup's or girdles correct?
Old Mar 21, 2003 | 12:22 PM
sgT's Avatar
sgT
gsr and itr pans are the same p72 part
all other b-series pans are the same but not same as p72 part
Old Mar 21, 2003 | 04:00 PM
delslow94's Avatar
Default Re: All b-series oil pans compatible? (sgT)
would the b18b fit on a b18c
Old Apr 14, 2003 | 05:43 PM
Vic Nyce's Avatar
Default Re: All b-series oil pans compatible? (delslow94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by delslow94 &raquo;</TD></TR><TR><TD CLASS="quote">would the b18b fit on a b18c</TD></TR></TABLE>
or B18A even...i have a hole in my P72 oil pan. i was searching around the junkyards before and no one has a GSR oil pan. i found a couple of B18A oil pans tho.
710dabber
Jan 1, 2016 04:37 PM
cdaiscool
May 24, 2011 07:22 PM
BoostnEK6206
Mar 23, 2008 02:51 PM
BlueTeg
Oct 17, 2005 08:49 AM
1SIKCRX
Jul 7, 2004 07:59 PM
