Question on passing State Ref w/ JDM '99 ITR
Old Mar 20, 2003 | 11:56 PM
d0nkeyxPunch's Avatar
Banned
Default Question on passing State Ref w/ JDM '99 ITR
Can I pass visual and emissions with JDM '99 ITR motor? What if I put USDM Si intake manifold, throttle body, thicker headgasket, and USDM OEM ITR header? I think you guys would know the best. Please help me. Thanks
Old Mar 21, 2003 | 04:25 AM
Apex i ITR's Avatar
From: Toronto, Canada currently residing in ATL, GA, USA
Default Re: Question on passing State Ref w/ JDM '99 ITR (EM1b16a)
Why would you need to replace the header or intake manifold. If it looks like a stock motor and the emissions are clean what would be the issue.
I don't live in Cali so excuse my ignorance adn help enlighten me.
Old Mar 21, 2003 | 06:56 AM
Philly_NBP_R's Avatar
Default Re: Question on passing State Ref w/ JDM '99 ITR (Apex i ITR)
well, considering that a usual inspection means that they plug into the OBD system, I would be concerned that the equipment won't read correctly... You could swap in a USDM ECU, but I'm not sure if the OBD II systems will function correctly w/ that motor. I would try to avoid an emissions inspection if at all possible, perhaps you could get a low mileage exception? (they have them in PA, not sure about Cali...)
Old Mar 21, 2003 | 07:12 AM
Banned
Default Re: Question on passing State Ref w/ JDM '99 ITR (Philly_NBP_R)
any more insights?
Old Mar 21, 2003 | 08:27 AM
98R-1144's Avatar
how/where do they plug into the ECU anyway? Do they disconnect the harnesses going into the ECU and connect directly to it... or they have their own "ECU" to connect to the harnesses to the car?
Old Jul 22, 2005 | 01:23 AM
marko_think's Avatar
Default Re: Question on passing State Ref w/ JDM '99 ITR (98R-1144)
Modified by marko_think at 9:07 PM 9/19/2005
Lynx
Oct 14, 2015 07:30 AM
USDM DUH
Jun 28, 2011 10:54 AM
kay_animation
Sep 8, 2010 12:42 PM
gtz
Sep 30, 2006 01:29 AM
smkngsr
Jun 9, 2004 01:36 PM
