tps sensor
Old Mar 20, 2003 | 09:40 PM
Vtecless212's Avatar
Default tps sensor
i'm putting a jdm b16 in a crx si and when i got the b16 the tps sensor was broken.
so would the tps sensor off of the d series motor work or do i have to buy a new or used one? thanks in advance
Old Mar 20, 2003 | 09:57 PM
xtrafastcivic's Avatar
Default Re: tps sensor (jdmturboef)
it will work...
i need to get a tps sensor !!!!! pleaaase someone has to have one...
Old Mar 20, 2003 | 10:01 PM
Default Re: tps sensor (XtraFastCRX)
thanks man i have about 6 d series tps sens let me know i will hook you up
Old Mar 20, 2003 | 10:25 PM
Louie B.'s Avatar
It will not work if the D-series TPS is from a DPFI.
Old Mar 21, 2003 | 03:21 AM
zCivic's Avatar
Default Re: tps sensor (thumpu77)
well the DX is debaiteable. There was a link that said how to do this. I'm gonna try it for s&g this weekend and see if I can get if figured out
Old Mar 21, 2003 | 06:31 AM
Louie B.'s Avatar
Default Re: tps sensor (zCivic)
believe me, I tried it.. the DX TPS does not work! the mounting screws are 90 deg offset and the resistance is all wrong.
Old Mar 21, 2003 | 10:02 AM
SiR Kid's Avatar
New User
Plus, they rotate backwards!
Old Mar 21, 2003 | 11:09 AM
zCivic's Avatar
Default Re: tps sensor (SiR Kid)
we will see.....
Old Mar 21, 2003 | 01:54 PM
AbaZ's Avatar
Its not worth the trouble to even **** with the dx tps, we tried for awhile, and its ******* gay.
get a mpfi b/d series or whatever, slap it on and calibrate it to .4 to .5 at closed throttle.
Jeff
Old Mar 21, 2003 | 08:40 PM
Default Re: tps sensor (AbaZ)
a tps off of a d16 with mpfi will work on b series but definately not a tps off of a d15 with dpfi i tried it today
[Modified by jdmturboef, 12:29 AM 3/22/2003]
Old Mar 21, 2003 | 10:09 PM
Louie B.'s Avatar
I've been looking for info on properly calibrating these... is that .4-.5 ohms of resistance? if so, between which 2 leeds?
Old Mar 27, 2003 | 05:40 PM
how do you calibrate the tps and how do you know if you need to?
Old Mar 27, 2003 | 06:48 PM
Dancing is Forbidden's Avatar
can anyone post a pic of the tps? I just want to see one.
Heres my B18a mani. Oh yeah and if you know what those things that are circled are, let me know/
[Modified by EF9_SiR, 10:51 PM 3/27/2003]
airikkCRX
May 15, 2010 06:47 PM
HNP
Sep 2, 2006 02:34 PM
B!^A@
Aug 10, 2006 09:17 PM
v8hnta
Jan 23, 2006 06:19 AM
ITR-00-1457
Jun 22, 2004 09:04 AM
