Engine is beginning to get really hot!
Old Mar 20, 2003 | 09:31 PM
dclub01's Avatar
Default Engine is beginning to get really hot!
My temp guage has been at the higher end lately... i think my water pump my be going out, or maybe the radiator?
How do i check if my water pump is working? Radiator? Etc.?
Any help appreciated!
Old Mar 20, 2003 | 09:39 PM
B18Cej1's Avatar
Default Re: Engine is beginning to get really hot! (dclub01)
if ur water pump is bad then it will leak onto the oilpan. if its not leaking then it may be old. when was the last time u changed it? and when does ur temp raise? and if it cools down then when does it?
Old Mar 20, 2003 | 10:23 PM
dclub01's Avatar
Default Re: Engine is beginning to get really hot! (whitericeEG)
can't remember the last time the water was changed, if ever! sad to say but it's true... when u say leak over to the oil pan... does that mean i would see antifreeze fluid on the oil pan?
the car heats up really fast, i'd say after about 10-15 minutes of regular driving...
my guage has the low end at about the 7 o'clock position... and the high end at 11 o'clock position, after about 10-15 min of driving, i'm sitting at about between 9 and 10 o'clock position...
hope that helps!
[Modified by dclub01, 7:25 AM 3/21/2003]
Old Mar 21, 2003 | 03:30 AM
Chiovnidca's Avatar
Have you checked your thermostat?
Old Mar 21, 2003 | 10:56 AM
funky49's Avatar
Default Re: Engine is beginning to get really hot! (TurboD16Chiovnidca)
Have you checked your coolant? Notice any puddles of water form under your car with the AC off when you sit idle for a while? Does your engine heat up only at red lights and cool down when you drive?
funk
Old Mar 21, 2003 | 11:03 AM
EL Vap133's Avatar
Do Accords have tempature sensors like Civics do? My Civic was heating up and it turned out to be my coolant temperature sensor...
Old Mar 21, 2003 | 11:08 AM
niedejb's Avatar
Default Re: Engine is beginning to get really hot! (Vap133)
If you have had the cooling system open, it may just have air in it.
Let me know and I can post bleeding instructions.
Old Mar 22, 2003 | 01:01 PM
dclub01's Avatar
I jus changed my radiator hose, cause believe it or not, it had expanded to an unusually large size, scared the crap outta me cause i thought it would burst!
Mixed up my coolant 50/50 and changed it...
The car still heats up... let's jus say the car is always at about 60-65% hotness on the guage?
How do i test the thermostat?
Old Mar 22, 2003 | 01:31 PM
Chiovnidca's Avatar
If it stays in that range, it's not overheating.
Old Mar 22, 2003 | 02:58 PM
dclub01's Avatar
So 60-65% is normal?... i always thought it stayed at or lower than 30-40%?
Old Mar 22, 2003 | 04:07 PM
Chiovnidca's Avatar
Most stay in the 1/4-3/4 range. They're not overheating until they get into the red. If it's going over 3/4, there may be a problem.
Old Mar 22, 2003 | 04:36 PM
GZERO's Avatar
i would check the thermostat just to be on the safe side
Old Mar 23, 2003 | 05:21 AM
niedejb's Avatar
Default Re: Engine is beginning to get really hot! (GZERO)
With the car running and warm open this bleeder to let the air out of the system.
I promise if you had a hose off and didnt do this it WILL run hot.
Opening this will spit and sputter coolant/air out. Open/Close every 10 seconds or so until it quits sputtering (4 or 5 times).
Old Mar 23, 2003 | 04:45 PM
dclub01's Avatar
Default Re: Engine is beginning to get really hot! (niedejb)
I'll try bleeding it and see if it helps... thx for the info! That's new to me!
Old Mar 23, 2003 | 08:21 PM
D114's Avatar
to test the thermostat
get a temprature gauge of some kind... and heat a pan of water up to the temprature stamped on the side of the 'stat. Toss it in the water and see if it opens, if it doesnt, you've got a bad one
it's cheaper to replace it than to test it and replace the gasket and everything... so just get a nice stant and replace.
Old Mar 24, 2003 | 05:36 AM
Baltz's Avatar
Ever since my radiator hose busted my cars temperature has never been right...maybe me not mixing with 50-50 could be the problem . I actually need to do that and change it...
Old Mar 24, 2003 | 06:27 AM
KCHybrid's Avatar
Default Re: Engine is beginning to get really hot! (4th gen accord)
Ever since my swap I have been having coolign issues. I get the whole gets hot as hell just idleing and then cools down when driving. I need to try the bleeder vavle.
Old Mar 24, 2003 | 01:06 PM
Chiovnidca's Avatar
Default Re: Engine is beginning to get really hot! (KCHybrid)
Does the cooling fan work?
Old Mar 24, 2003 | 01:52 PM
KCHybrid's Avatar
yup, actually funny you mentioned it the cooling issues didnt really start untill I noticed that the fans were unpluged this past saturday.
Old Mar 29, 2003 | 08:22 PM
KCHybrid's Avatar
I am being lazy so I am just going to copy and paste this from a differnt board...
The swap has been running great untill recently. Been having major cooling issues , if I let it sit and idle or am in heavy stop and go traffic it will start to heat going past the half way point in some cases. Today after I bled off the air that like an idiot I forgot to do after I finished the swap. Any way take it out and it shots to red line in a matter of minutes after I let it warm up. It did bleed off quite a bit of coolant (antifreze) that I did not replace. Is it getting so hot due to me not replacing the coolant or is it a differnt issue? My fans are not turning on when it warms up but only after I shut the car off will they come on and then shut off once it cools down. I am really lost at this point as to what this could be. I am not throwing any codes. Also I have been getting an infrequent idle surge where it goes from 1k up to 2k and back and forth. It comes and gos at random most of the time coming after I have stated the car and have drove a little or its siting and idleing.
Cliffs notes: Temp gauge in car indicates that motor is getting very hot, fans only kick on when I shut the car completely off, bleen air out of colant and made issue worse, did not add more colant, surging idle at odd times from 1k-2k, no codes, when swap was done front sensor for second fan was carred over
Thanks for any help in advance
AudioFunk
Nov 14, 2013 12:58 PM
choua01
Mar 21, 2009 08:19 PM
eg8guy
Nov 2, 2008 12:21 PM
HondaGuy02
May 4, 2007 04:22 AM
sdr KEL
May 4, 2006 02:25 PM
