Tricking secondary o2 sensor with testpipe
Old Mar 20, 2003 | 09:12 PM
ITR21's Avatar
Default Tricking secondary o2 sensor with testpipe
couldn't find any solid info on this. I have heard about people with test pipes wraping their o2 sensors with tin foyle. Does the sensor have to be in the testpipe bung hole if you are wrapping it in tin foyle?? just lookin for some feed back on it.
Old Mar 21, 2003 | 03:17 AM
canuck-mx6's Avatar
Default Re: Tricking secondary o2 sensor with testpipe (ITR21)
o2 sim.......
Old Mar 21, 2003 | 03:49 AM
SurferX's Avatar
Or get a testpipe that has some catalyst material around the O2 bung.
edit- Only needed on the secondary O2.
[Modified by SurferX, 4:50 AM 3/21/2003]
Old Mar 21, 2003 | 04:38 AM
H-PIMP's Avatar
Default Re: Tricking secondary o2 sensor with testpipe (SurferX)
Tin foil yes, screwed into bung hole yes.
Old Mar 21, 2003 | 05:23 AM
AW's Avatar
AW
Default Re: Tricking secondary o2 sensor with testpipe (H-PIMP)
We tried a simulator on a 2001 S2000 it did not work. I believe the same would happen on a 2001 ITR. Just switch the ECU to an OBD1 and you won't have to worry about it.
AW
Old Mar 21, 2003 | 05:30 AM
AssPenny's Avatar
Default Re: Tricking secondary o2 sensor with testpipe (AW)
Some one on here did it a while ago using this diagram (I think it was BlackR). I'll see if I can find the post
[Modified by AssPenny, 9:31 AM 3/21/2003]
Old Mar 21, 2003 | 05:34 AM
AssPenny's Avatar
Default Re: Tricking secondary o2 sensor with testpipe (AssPenny)
Here u go: https://honda-tech.com/zerothread?id=221347
Old Mar 21, 2003 | 05:43 AM
Dr Pooface's Avatar
Will this trick work even if I don't screw the sensor back into the exhaust? My testpipe doesn't have a bung.
Old Mar 21, 2003 | 05:45 AM
AssPenny's Avatar
Default Re: Tricking secondary o2 sensor with testpipe (Dr Pooface)
That I don't know... sorry.
Old Mar 21, 2003 | 05:53 AM
Larkin W.'s Avatar
You screwed tin foil into your Bung hole?
Dude, thats SICK
[Modified by EbboyPSi, 9:13 AM 3/21/2003]
Old Mar 21, 2003 | 05:58 AM
SlapSmak's Avatar
Default Re: Tricking secondary o2 sensor with testpipe (EbboyPSi)
i just screw my o2 into the test pipe bung, which is long enough not to allow the 02 to sit in the exhaust stream and i get no CEL. No screen or anything in the bung.
Old Mar 21, 2003 | 07:56 AM
ITR21's Avatar
I was wondering also if you have to. because i am getting a testpipe soon but plan on converting to OBD1 in about 3 months. I dont wanna get a testpipe with a bung if I don't need it.
Old Mar 21, 2003 | 08:04 AM
ITR21's Avatar
wow great link ! maybe someone could redo the diagram with the proper colors and a bit bigger for easyier reading ! thanks
Old Mar 21, 2003 | 12:32 PM
Hairy Gorilla's Avatar
Default Re: Tricking secondary o2 sensor with testpipe (SlapSmak)
Wow, I need to try that w/ my GSR. I have a test pipe waiting at the house. Maybe i'll go for it this weekend and hope for the best. If it gives a cel, I'll try out the diagram the person gave....
So how the hell do you order these parts and radio shack? Just tell someone at the counter those numbers, and they will find the stuff?
Old Mar 21, 2003 | 12:34 PM
Default Re: Tricking secondary o2 sensor with testpipe (Tim Maryak)
Also, would it screw things up if I threw my 2.25in test pipe onto my stock gsr headers and exhaust?
Old Mar 21, 2003 | 12:41 PM
done's Avatar
i have mine siting inside my car wrapped in alunium foil.. it throws a code every now and then..
Old Mar 21, 2003 | 05:10 PM
nightrider's Avatar
interesting! i am going to have to try this out...
Old Mar 22, 2003 | 01:06 PM
kkim's Avatar
try emailing zipzoo_22@hotmail.com
he was selling an o2 simulator. don't know if it would work with no o2 at all, but try asking him to find out exactly how it works.
good luck.
Old Mar 22, 2003 | 04:36 PM
Allstar's Avatar
New User
Default Re: Tricking secondary o2 sensor with testpipe (Jordo)
I used foil on my o2 and I zipp tied to the sway bar, it throws a code every couple months.
Old Mar 23, 2003 | 10:35 AM
Dr Pooface's Avatar
Default Re: Tricking secondary o2 sensor with testpipe (Allstar)
DAMMIT! I just went to Radio Shack with the part #'s. Apparently US and Canadian stores use a different # scheme. Now stupid me has to figure this shiat out.
Edit: anyone have pics or better discriptions of the parts needed?
[Modified by Dr Pooface, 11:38 AM 3/23/2003]
Old Mar 23, 2003 | 04:23 PM
DR. ON POINT's Avatar
Banned
get the 02 wrap it in aluminum foil, zip tie it to somewere in the engine bay.....
thats what I did, no CEL for 8 month
Old Mar 23, 2003 | 04:36 PM
ITR21's Avatar
damn, let me know if u figure out the part numbers for canadian radio shack.
Old Mar 23, 2003 | 08:11 PM
JBBNJ609's Avatar
so , if i buy a test pipe , what do i need to do , now that im OBD1 , and what do i do if i DONT have a bong hole on the pipe , should i get one with or with out , thanks . .. .
Old Mar 23, 2003 | 08:14 PM
Dave-ROR's Avatar
Default Re: Tricking secondary o2 sensor with testpipe (jason bouchard)
like others have said, just wrap the o2 sensor in tin foil and put it in the car (or tie it somewhere under neath) or just pull it into the passenger compartment without wrapping it if yu want. Code 67 should be thrown everyonce in awhile but just reset the ecu.. or don't, it doesn't effect performance anyways.
hell, I just removed the CEL light. My car has had a code 67 for a long, long, long time.
Old Mar 24, 2003 | 04:30 AM
AW's Avatar
AW
ITR21
If you are OBDI you will not need the secondary O2 sensor as OBDI was only made for single O2 sensor. Just tie it up somewhere or wrap it, it doesn't really matter.
You may want to buy a test pipe with the second bung so you have some place to plug the secondary O2 sensor.
AW
