remove back seats? What is it like under there?
Old Mar 20, 2003 | 05:42 PM
hs2000's Avatar
Default remove back seats? What is it like under there?
In the next few weeks I will be adding a sub in my 94 acoord 2 door. I am feeling a little bad about adding the extra weight so I was thinking about removing the back seats. Does anyone know how much they weigh? Do you think that without the seats in the way the sub would be louder? Whats it like under the seats? Is it bare metal or carpet? If its bare metal, how would I go about putting carpet down? What is you guys general thoughts? sorry for all the Qestions, I tried a search.
While I am making a post...
A few months ago I was driving down the highway when the wind ripped my front drivers side wheel well liner right out! Should I bother to replace it? There is some wires exposed but they are insulated pretty good. what about rust?
Thanks a lot for all the help, I love this board. I learn so much stuff.
Edit:where would I buy a new wheel well liner?
[Modified by hs2000, 2:57 AM 3/21/2003]
Old Mar 20, 2003 | 05:50 PM
iam7head's Avatar
Default Re: remove back seats? What is it like under there? (hs2000)
the back seat i very light..not worth it imo
it's a aluminum plating with a puffy stuff wrap around with leather/cloth.
people edge/shave away the undercoating after they remove the seat.
it's gonna be bare metal after the seats are taken out.
I took it out once
iam7head's Avatar
Default Re: remove back seats? What is it like under there? (iam7head)
the liner is pretty cheap..just get it cover up
Old Mar 20, 2003 | 06:18 PM
Crono139's Avatar
My friend had to take out the back seat in his Stealth because one of the seat belts got stuck. I was over his house at the time, and I saw a bunch of padding, and aluminum.
Old Mar 20, 2003 | 06:27 PM
TypeSH's Avatar
Default Re: remove back seats? What is it like under there? (Crono139)
they dont weigh much. If you want to save weight, replace the front seats. The accord front seats weigh a ****!
Old Mar 20, 2003 | 08:31 PM
ShamMaster's Avatar
Default Re: remove back seats? What is it like under there? (TypeSH)
LOL, I did that. Took out the stock EX leather seats in my accord, and put in Sparco Torino replicas. Hella light. Then came the seat bracket and sliders. Heavy! They're probably lighter than the seats, but not by much. As for the backseat, don't take it out. Too much headache. Its really light. It comes apart in 4 pieces.
Old Mar 20, 2003 | 08:35 PM
immalooser's Avatar
word, totally true.
Old Mar 20, 2003 | 10:23 PM
iam7head's Avatar
Default Re: remove back seats? What is it like under there? (immalooser)
lol, love the way the bride seat sits.
tenzo R's is okay too, at least better than i predicted
Old Mar 21, 2003 | 11:21 AM
accordexchange's Avatar
Does anyone know how much they weigh? Do you think that without the seats in the way the sub would be louder? Whats it like under the seats? Is it bare metal or carpet? If its bare metal, how would I go about putting carpet down? What is you guys general thoughts? Should I bother to replace it? There is some wires exposed but they are insulated pretty good. what about rust? Edit:where would I buy a new wheel well liner?
i'm not sure how much the rear seats weigh but you do save a few pounds... the front passenger seat is definitely heavier if ican remember correctly... i would imagine the subs being louder cause there's nothing there anymore for sound deadener... on the rear seat (where you sit down), it's metal but it has black tar on it... on the floor, there's the carpeting and below that is some more tar stuff... i hear you can chip it off, you can save about 10-15 lbs (correct me if i'm wrong)... once you take off the rear seats, you'll see how the carpeting is aligned... if you got the money to replace it, go for it... you'll need to remove the front seats, etc... right now my carpeting is gone but my floor mats are still there... some of the wiring is exposed... i haven't noticed a rust problem yet for the interior... you can get a new wheel liner online or from honda...
edit: here's an old thread of mine where i took out my rear seats... hope it helps...
https://honda-tech.com/zerothread?id=302718
[Modified by accordexchange, 8:24 PM 3/21/2003]
Old Mar 21, 2003 | 07:57 PM
hs2000's Avatar
Default Re: remove back seats? What is it like under there? (accordexchange)
Thanks for your help. After looking at those pics I think I will keep the seats. I have already come to turms that my car is slow.
But back to the wheel well, Does anyone think there is a problem with not having one? Trying to figure out if its my worth my time and effort.
Old Mar 21, 2003 | 09:22 PM
whoa its len 2's Avatar
Ive been driving around without both fender wall linings for at least 6 months. Only problem I have is it gets dirty and my filter gets wet when it rains. Oh well, hey cooler air! Just make sure your wires are secure and you should be fine.
Old Mar 22, 2003 | 11:23 AM
97F22B2's Avatar
Default Re: remove back seats? What is it like under there? (whoaitslen2)
Heres what i did when i took out my back seat becasue the previous owners like used it as a rag or soemthing
All it is is speaker box carpet and heavy duty souynd deadner underneath, looks ok but the capret color is a lil off, o well.
Old Mar 22, 2003 | 11:55 AM
4doorH22's Avatar
Here's what's under there:
If anyone thinks I was going for weight savings, nope:
Here are some weights (in lbs):
sound deadening 20.0
passenger seat 39.5
rear seat bottom 16.5
rear seat back 24.0
floor carpet 10.5
floor mats 11.0
front door panels 11.5
rear door panels 11.5
misc trim 1 9.0
misc trim 2 8.5
headliner 4.0
trunk side liner/rear deck 6.0
trunk floor/rear liner 8.0
sunroof 36.0
Removing the rear seat bottom and back will save you ~40.5 lbs, about 25~33% the weight of an average passenger.
Old Mar 22, 2003 | 01:39 PM
4doorH22's Avatar
That may be fine in CA, but in the snow states where they salt the roads, you don't want that salt and **** getting all stuck up in the metal nooks and crannies of your inner fenders. IMHO, the lining is there to protect the metal and reduce noise from flying rocks. It's also logical to make sure the CAI stays as dry as possible.
Old Mar 22, 2003 | 01:42 PM
that's a bad attitude... you don't always have to spend a lot to go faster... there's a few junkyard setups that have produced good results and a surprisingly low price and sometimes you might find a good deal... you might not have the fastest car ever but with that kind of attitude, you accord will never be faster than it is now...
you might as well get it cause you'll hear more road noise (like sand and rocks from the road, etc) plus i'd rather get the lining dirty than to have the stuff underneath it dirty...
Old Mar 22, 2003 | 02:15 PM
Old Skool's Avatar
everyone always asks me if i did it for wieght reduction..the thing is i have racing seats and its a pain to get back there and i dont like people in the back anyway. yeah, it really has no benefit to freeing horsepower..the stuff only wieghs like 13 lbs
huge230
Oct 28, 2010 11:04 AM
exz0n-.-
Nov 12, 2008 08:14 PM
baiwldrnner
Honda Civic (2001 - 2005)
14
Jun 13, 2007 10:29 AM
numotive
Sep 18, 2005 10:58 AM
PRELUDESH_UWO
Jun 13, 2005 06:07 PM
