Piston to Valve clearance questions...For the N/A guru's
Old Mar 20, 2003 | 05:20 PM
96SR-V's Avatar
Default Piston to Valve clearance questions...For the N/A guru's
Ok so I've got some good power now but I'm already thinking of going a little wild for next year so here are some questions for u guys...
This is the kinda setup I'm looking for:
12:1 or 12:5:1 compression pistons
stage 2 or 3 cams from skunk
and some .5 mm oversize SS valves from skunk maybe high comp
How can I ensure that the valve reliefs on the pistons will be big enough? What should I know before I piece this setup together? Any other recommendations?
Old Mar 20, 2003 | 05:23 PM
MugenPoweredLude's Avatar
Default Re: Piston to Valve clearance questions...For the N/A guru's (96SR-V)
you could probally get a much better response from the N/A thread..post it up in there and the gurus will be all over it..
I could be wrong but I think you can clay the motor to see if the valves would tap the pistons???? dont quote me on that
Old Mar 20, 2003 | 08:53 PM
One Slow Lude's Avatar
Default Re: Piston to Valve clearance questions...For the N/A guru's (MugenPoweredLude)
Yeah you can clay it and it was already asked in that NA thread so look there too, I know cause i asked.....
Old Mar 21, 2003 | 05:34 AM
Default Re: Piston to Valve clearance questions...For the N/A guru's (POSlude97)
So youre going N/A??? I feel ya on that one...
Hey me and you should start our own club...The We're Too Worried About Blowing Our Engines from Turbo cuz We Dont Got the Money To Fix It So We're Going N/A Club
I know the name needs work
Old Mar 21, 2003 | 06:46 AM
rjr162's Avatar
T.W.T.W.A.B.O.E.f.T.c.W.D.G.t.M.T.F.I.S.W.G.N/A.C
... is there even a windshield big enough for your banner?
Old Mar 21, 2003 | 07:35 AM
96SR-V's Avatar
Well u could say I'm already N/A I've got S-pistons in w stage 2 cams and hondata... I run consistent low 14's 14.1 @99.7 is my best on street tires... But I really wanna get into the mid to low 13's if possible so I'm thinking of going a little further...
Old Mar 21, 2003 | 11:34 AM
HA HA HA HA HA HA HA H AHA HA HA HA HA
I am also worried about the atts and the fact that i am going to NC to finish school, along with the money issue.....but if i can get into the mid 200hp NA i think ill be happy till i get out of school finally.......plus if the atts doesnt work then we already have a 80 lb disadvantage from the start
def. have to work on the name
Old Mar 22, 2003 | 03:21 AM
HotWheelz's Avatar
i'm not sure about the .5mm oversized if your going stage 3.... i'll know once i receive my head... until then everywhere i see they say you cna't because if you try to dial in your cams (gears) you may have valve-valve collision on your overlap stroke.. since stage2 and 3's have long durations on them.. i know my stage 3's have a VERY long duration.. I opened for ferrea's stock size that .5mm will not even contribute to .5hp if that... and you need to install new seat's in the head, then port to match the new seat etc etc etc....
Old Mar 22, 2003 | 06:48 AM
96SR-V's Avatar
Default Re: Piston to Valve clearance questions...For the N/A guru's (HotWheelz-turboh22dx)
fair enough...I've heard oversize valves would offer minmal gains as well probably not worth the hassel.. Perhaps some really good headwork and super aggressive cams will help me get to where I want and also getting rid of this shitty DC header.
Murk 'EM
Apr 27, 2009 08:15 PM
DaInFaMMuS1
16
Mar 9, 2009 05:09 AM
Twisted Image
Feb 10, 2009 09:38 PM
Speedra500
Jun 17, 2004 02:41 PM
sieger
Oct 10, 2002 08:38 PM
