ALL motor guys....
Old Mar 20, 2003 | 04:45 PM
BLuDoHcReX's Avatar
Default ALL motor guys....
I was wondering what engine you guys are using. 'cause I'm planning to go all motor. and what kind of numbers are you pulling with these engines?? and in what kind of car? hatch? crx? thanks
Old Mar 20, 2003 | 04:57 PM
Kaan's Avatar
Loved
Community Favorite
Default Re: ALL motor guys.... (BLuDoHcReX)
I have a B20Z that i'm building, its from a 2000 CRV and it is supposed to have more compression then the B20B... but till its done i wont really know. I'm building to to Honda Challenge spec... so it wont be a straight line monster, it will be a road racer motor... but i'm cool with that. i know alot of the straight line guys are running the good old H22... the guy building my motor drags his H22 in all motor. i doubt i helped much... but i figured i would throw out my 2 pennies.
Old Mar 20, 2003 | 05:54 PM
altoid's Avatar
Default Re: ALL motor guys.... (MMsportsRexSi)
im building up my sohc zc, its in essence a d16a6 if you didn't know, and i won't be expecting more than 200 crank hp. Im going to go into some small time rallycross events then move on to some small time rallies. Ohh this is also in a civic wagon 4wd. Granted its heavy for a honda (2505lbs w/ all options) it will still be very good for rallycross. I am in the process of planning out a b20/vtec. That'll be N/A as well, i'll have a 4wd tranny mounted to that also. I believe i'll end up getting an oldschool ls block and boring it out then stroking it and raising the compression to something aroun 12.5:1. Probably lots of mid range on that since it'll also be for rally.
Old Mar 20, 2003 | 06:04 PM
Fa-Q Racing's Avatar
Default Re: ALL motor guys.... (altoid)
My CRX has a SOHC ZC, and with DC Sport Headers and a Short Ram Intake, I run mid 14's, That is fast enough for me.
Old Mar 20, 2003 | 07:01 PM
BLuDoHcReX's Avatar
Default Re: ALL motor guys.... (Fa-qracing1991)
Is an LS/VTEC a good set up to run? but I heard it blows easily. We dont have many shops up here that can blue print it (do it the right way) what do you guys think about the set up.??
Old Mar 20, 2003 | 10:21 PM
EF_LSVtec's Avatar
I have lsvtec set up with basically us type R internals miled head port xcept for ctr cams. Very conservative daily driver set up, 11.2 compression and does not ping on 91 octane...only problem I've had so far is when my fan switch broke, motor overheated and caused cyl. head and block to warp...got the head milled ($40) today but I have a race on Sunday (autocross) so we're putting it together tomorrow and I'm going to run it with the block as is. (currently first in my class so cant afford any downtime) Then get it all dismantled next week and send all to the machine shop to be milled...here are my dyno numbers.
Old Mar 20, 2003 | 11:02 PM
customx_'s Avatar
New User
Default Re: ALL motor guys.... (EF_LSVtec)
igniton problem in run #1?
Old Mar 20, 2003 | 11:09 PM
EF_LSVtec's Avatar
Default Re: ALL motor guys.... (usdmRob)
no...ecu problems. Installed stage 2 hondata and reprogrammed fuel map reason for the increase in whp...
victor90
Jun 16, 2007 06:28 PM
EG6_GSR
Jan 19, 2006 05:05 PM
fastwanabe
Jan 23, 2005 05:30 PM
