Different car wont start...1990 dx hatch
Old Mar 20, 2003 | 01:01 PM
CRXMATT's Avatar
Default Different car wont start...1990 dx hatch
The car is getting fuel, new distributor, rotor, plugs, all that good stuff......still wont fire.....any ideas
Old Mar 20, 2003 | 01:14 PM
Fa-Q Racing's Avatar
Default Re: Different car wont start...1990 dx hatch (CRXMATT)
Battery, Battery Cables, Spark Plug Wires, ignition?
Old Mar 20, 2003 | 01:21 PM
CRXMATT's Avatar
Default Re: Different car wont start...1990 dx hatch (Fa-qracing1991)
everything is good, that is why I am so stumped, it is all new
Old Mar 21, 2003 | 09:43 AM
allicedout's Avatar
if the cars cranking but not starting then u proli need an ignigtor. I had this problem with my 91 integra. if it doesn't crank check ur starter.
Old Mar 21, 2003 | 01:23 PM
mr. carpenter's Avatar
Default Re: Different car wont start...1990 dx hatch (allicedout)
main relay?
Old Mar 22, 2003 | 05:19 PM
MYT4G's Avatar
Had the same problem on my old 90 std hb. Check voltage and resistance against the Honda specs on the ignition coil and ignitor unit inside the distributor cover with a multimeter. I ended up replacing both of em b/c the values were out of spec then she fired right up...Good luck
Old Mar 22, 2003 | 05:25 PM
CRXBart's Avatar
Yep ignitor. Also you might want to take off your dist. cap and look inside sometimes the rotor comes loose, and fires sporaticly(sp). Not on time just fires and isn't enough to run the car. I've had this happen before has many others before me. Check that first if it is good, bad ignitor.
Old Mar 23, 2003 | 05:35 AM
civbeater90's Avatar
Default Re: Different car wont start...1990 dx hatch (CRXBart)
check your grounds also
mastapw7
Jan 21, 2012 11:31 AM
honda_tuner_2007
Apr 19, 2007 09:43 AM
erik92DA
Jun 8, 2006 08:16 PM
asianpoet
May 24, 2005 02:49 PM
HYBRIDGSiR
Nov 23, 2001 07:32 AM
