When doing crower camshafts+ valve spring kit, should i do cam gears as well?
I would.
So I could get it all dyno tuned down the road. You might as well you know. Since you already have the cams and stuff out, you might as well put the cam gears on.
Do it right the first time. Do it once.
you think it would be wise to also to safc? along with crower 403's and cam sprockets, and retainer kit?
its silly to put in cams without cam gears... you wont be able to tune it and extract maximum hp.
you guys think i could do all the above for about 1500 or soo???
Crower 403's, valve spring kit, crower cams, or skunk2 cams, and safc.
I guess they forget to mention
better fuel injectors and fuel regulator
as well
w/a chipped computer will do a better job
as well
as well
as well
