help me. my car is lagging
Old Mar 20, 2003 | 09:13 AM
jerknob's Avatar
Default help me. my car is lagging
I have a 93 SI and I just got a tuneup, but my car is still having lagging problems during acceleration. They put in good spark plugs, replaced fuel filter, replaced PCV valve, and other stuff; I also have good thick performance ignition wires. It feels like i've lost horsepower even though I have a few performance mods because this is not the way a car with a cold air intake and cat-back exhaust should be. I even regularly use fuel injector/fuel system cleaner. I was thinking that I should clean my K&N air filter and use an intake cleaner, but what else can I check for that could be causing my problem????
Old Mar 20, 2003 | 09:41 AM
19924ws's Avatar
Default Re: help me. my car is lagging (jerknob)
Could be bad gas, wrong gap on the plugs, loose ignition wire(s). Clean your intake and see how that works for ya. Then try the rest of those. Mike
Old Mar 20, 2003 | 09:57 AM
roadawg's Avatar
How many miles are on your car, try checking the compression in your cylinders.
Old Mar 20, 2003 | 10:29 AM
ApexiAccord's Avatar
try checking your timing belt to see if everything is TDC and lined up correctly it could of jumped a tooth on da cam gear
Old Mar 20, 2003 | 10:33 AM
jerknob's Avatar
Default Re: help me. my car is lagging (ApexiAccord)
well it has 94,000 miles. the compression in the cylindars may be bad and also i think 100k miles is usually when the car requires a timing belt change. I don't think the gapping problem in the spark plugs are a problem since they are brand new and also the ignition wires are only 3/4 of a year old.
Old Mar 20, 2003 | 10:39 AM
trueb's Avatar
change your wires back to the FACTORY! thats most likly your problem. hondas dont like aftermarket wires.
Old Mar 20, 2003 | 04:40 PM
spiveslude's Avatar
Default Re: help me. my car is lagging (trueb)
do you have gas
Old Mar 20, 2003 | 04:59 PM
prelude22085's Avatar
Change timing belt. Unless you want to re-build the engine.
Old Mar 20, 2003 | 05:18 PM
MugenPoweredLude's Avatar
Default Re: help me. my car is lagging (prelude22085)
I have a similar problem...when im accelerating from 1K to 2900K its got some serious lag and my motor only has 32K on it...i think i should change the plugs....
doubleoazn03
12
Sep 5, 2022 09:10 PM
aquafresh93
Apr 14, 2010 01:30 PM
manintux
Jul 7, 2008 05:52 PM
integ_lude
Aug 17, 2007 10:24 AM
gworthyunit
Nov 19, 2006 10:28 AM
