4gen seat compatability thread - please read
Old Mar 20, 2003 | 08:51 AM
serious's Avatar
Default 4gen seat compatability thread - please read
seems a lot of people are wondering about what seats fit in what cars. we also know that the seats changed between some years in the 4gen. let's try and get all the information in one place.
if you put different seats in your 4gen please list your car's year and model, what year/model seat you put in, and what you needed to do to make it work. also, if you know for fact that the seats are the same between certian years, please put that as well. again, please only put information you know to be correct.
[Modified by serious, 12:54 PM 3/20/2003]
Old Mar 20, 2003 | 08:54 AM
serious's Avatar
Default Re: 4gen seat compatability thread - please read (serious)
i'll go first.
- 89-91 crx si seats are the same.
-90-91 civic dx and civic si seats are the same.
- installed 91 crx si seats in a 90 dx hatch. it required using the crx outer rail and the civic inner rail, and making 4 brackets for the 4 places the rails bolt to the seat. the crx seat sits further back than the civic seat.
[Modified by serious, 11:55 AM 3/27/2003]
Old Mar 20, 2003 | 09:39 AM
HatchBox's Avatar
Skoobie no more...
i put 98 integra seats in my 90 hatch...my friend used 92 integra rails...all 4 bolts bolted to the floor and he welded the rails to the seats
[Modified by rsk436, 1:40 PM 3/27/2003]
Old Mar 27, 2003 | 07:02 AM
subgeniusdude's Avatar
Default Re: 4gen seat compatability thread - please read (rsk436)
I put 90-93 Integra seats in my 91 Std hatch.You have to use your outer Civic rails on the Integra seats.Wire that runs between tracks so the seat can slide back and forth has to be shortened a bit.Use the outer trim from your Civic seats.Only 3 holes will line up,the front two and one of the rear.I just drilled an extra 1/2 inch hole in my track right beside the stock hole and threaded a 2" 10 mm bolt in.They fit and look great!Also,92-95 Civic seats will fit,but they sit HIGH as hell,I had them and traded for the Integra seats.You have to,ugh,massage the last bolt in but it will go.
1988crxdx
Jun 3, 2009 12:51 PM
powers89si
Oct 9, 2007 02:10 PM
EF9 JAMS!!!
13
Mar 9, 2006 07:13 PM
eastcostJDMfanatic
Nov 6, 2003 07:46 AM
illmeth0d
Apr 13, 2002 04:18 AM
