High comp w/low boost or Low compw/high boost
[Modified by accordexchange, 6:53 PM 3/20/2003]
higher compression will make it better before the turbo is spooled. remember f23s are 9:8:1 compression and have no problem with 10lbs of boost. you can't boost that much anyways onstock internals to make having low compression really worth it. if you have a person who can tune the car than having 10:0:1 compression like an h22 shouldn't even matter. it's all in the hands of the person tuning the car.
I'd rather have a middle of the road in this instance. Instead of 10:1 w/5psi or 8:1 w/15psi, I'd go with a more optimized setup. I don't want so low of a compression that the turbo does not want to spool and the engine is weak off of boost. I don't want so high of a compression that one warm day and the motor is done. Maybe a 9.5:1 w/10psi would be the better comprimise. Sure it's not the best in every category, but you can still get the benefits of both sides.
RACE ONLY ENGINE: HIGH COMPRESSION + or - 11:1
STREET ONLY ENGINE: LOW COMPRESSION + or - 8.5:1
High Compression: lil amount of error or engine could be blown
Low Compression: High amount of error before engine blows
so as brandon said, a 9.5:1 or 9.0:1 would be a good compromise.
Also a high compression turbo engine would create lot's of heat, so if you are going to do something like this, make sure you have the means to dissipate the heat and maintain the engine at his operating temp.
There is a table that stated the compression ratio of an engine and the boost you need to acomplish the same boost, meaning it tells you what static compression it would create, pretty good, but i can't find it!
The higher compression will always make more power.
If you can afford it, go high compression, high boost.
I chose low compression on my build since I want a little more comfort factor for street driving in all conditions and weather.
am running 10.2:1-10.5:1 comp with boost after i tune ill run be running 16-18psi on c16 race gas and 14-15psi on pump gas
but only do this if you have a standalone
well this is what i have. I currently have 3 f22b1 motors. I have a build one with JE Pistons (8.5:1) Crower rod, etc.... Well the problem is that I was at a drag strip running my car to tune it alittle and ...... well.... my #4 piston hit #4 sparkplug.. due to the fact that the machine shop mill my head toooo much.... so i have a crack piston now. And my share motor that is in the car right now on 10psi....... is blowing smoke out of my tail pipes....(rings, or valve seals).. So im getting my built motor ready to be put in my car. That well im asking for your opinons. thanks
im an using the VAFC and MF2 to tuned my fuel. I car runs great on 10psi.... I think my girlfriend mess it up alittle bit.... when she was racing a spraying lude.
[Modified by NXAccordTO4B, 6:02 AM 3/21/2003]
rb08
Aug 26, 2003 07:52 AM
civicqm
May 30, 2003 08:39 AM
