jimfab traction bar
how much torque should i tighten the bolts that hold the tie rods to the lower control arm brackets and where it connects to the bar. and how my preload should i set it at.
I'd torque the bolts to oem specs. and set preload by hand. Start with a couple turns and see what results you get before you keep crankin on them.
[e] Preload is toward the front of the car (shorten the rods)
[Modified by sackdz, 9:43 AM 3/20/2003]
JDubya
Sep 2, 2002 04:37 AM
