front bumper support removal
how exactly do you take off the front bumper support? is there any reason for it to be there besides safety and weight? any help would be appreciated
there are two screws in each wheel well that need to be removed, then take out the rectangle parking lights, then there will be two 14 mm bolts on each side, you can take them out, then you lift the bumper up, off two little tabs then it is off the car, then to remove it from the bumper cover you have to remove the screws off the top of it.. if you want to remove it for weight reasons you can make a new support out of 1/2" angle iron, i did it works good, and it took off like 10 pounds from my hatch
Might take a second thought on removing it. If you were ever in an wreck, it could come back an haunt you. If the insurance company ever found out about it, then alot of liability issues could arise out of it. Espeically if someone was hurt or killed...
[Modified by 88_SC_CRX_Si, 8:39 AM 3/20/2003]
the car is going to be race only in a couple of monthes, i have thought about that over and over again in my head and i am not concerned with it, but thanks anyway for the advice.
dont take it out unless your going to take ur car to the fabricator to have some brackets welded on so u can still screw on the bumper...i took mine off my crx and you have to hold on the bumper with zip ties in the front, it kinda sags.
i posted it in my orriginal post, you have to "frame" it out with some type of metal, i used a peice of 1/2" angle iron i got from Home Depot, i just made a
\____/ shape comin goff the front of the car, then screwed the cover to the top of it, then used two more small peices, one for each side to hold the bottom in place, looks factory, and saved about 10 pounds maybe a little more
nice weight saving mod, btu like posted above i wouldnt suggest it on a street car, even thought thats what i did it on
there was a post with the jdm bumper support pic somewhere dont feel like searching right now but the support is just enogh to hold the bumper up and bolt it to the car ur bumper suport isnt all that much but to protect u in a 30 mph hit at most
dont do it matt... we got in an accident adn that **** help stop the impact.... you will regret it if you ever crash(forbid it does happen) so i suggest thta you dont do it....
7panget
10
Apr 22, 2009 06:16 AM
udm_motorsport
May 6, 2004 08:36 AM
CHRIS 1.8
12
Apr 27, 2003 07:43 PM
rasta420
Jul 3, 2002 08:50 PM
