Camber kits??
Old Mar 19, 2003 | 10:06 PM
projecthybrid04's Avatar
Default Camber kits??
What cmaber kits do they sell for an 89 std hatch????, i have tokico blues with eibach sportline springs. Do they sell skunk 2 ones???? what shoild i get. thanks
Old Mar 19, 2003 | 10:44 PM
d-wreck's Avatar
Default Re: Camber kits?? (projecthybrid04)
camber kits are all the same practically. if you plan on getting better suspension i wouldnt get a camber kit since youd have pillow mounts.
you should pick your camber kit more around with the amount of drop your going to go with. ie the amount the kit is able to correct in degrees.
id check out groupbuycenter.com or check classifieds
derek
Old Mar 20, 2003 | 03:04 AM
USDM 4G VTEC's Avatar
the best deal i found..... and this is what i got right now.... perform great!
http://www.iapdirect.com/item.asp?invid=119
[Modified by USDM 4G VTEC, 7:04 AM 3/20/2003]
Old Mar 20, 2003 | 10:19 AM
SiR Kid's Avatar
New User
Default Re: Camber kits?? (USDM 4G VTEC)
Specialty Products has a Ball Joint type of camber kit for our cars. I'm getting that cause I'm sure my car could use ball joints also!
They're $180 for both sides in the new JCWhitney catalog.
Old Mar 20, 2003 | 10:34 AM
HybridFiend's Avatar
My local tire store can beat the SSP camber kit prices on that site. I had the rear upper "EZ" arm "in poly" price at $80 each and the front "extreame upper ball-joint" priced at $85.
solerizr
Sep 18, 2006 10:59 AM
Jowee
Dec 11, 2002 12:51 PM
ESCALVANTE
Jan 31, 2002 10:36 AM
