major shaking ......
Old Mar 19, 2003 | 09:50 PM
dRuNk-dRiVer's Avatar
Default major shaking ......
alright ... here we go.... when i am applying my brakes in motion. [doesnt matter wut speed ] i get a hard shake.. like a non stop shake till i stop.... i've been told to just go resurface my rotors and the problem will be gone. but i feel that its a little more than that.. well help me plz
Old Mar 19, 2003 | 10:41 PM
d-wreck's Avatar
Default Re: major shaking ...... (pHadEd)
your rotors are warped...
derek
Old Mar 20, 2003 | 12:36 AM
shortyz's Avatar
Default Re: major shaking ...... (d-wreck)
new rotor time!
Old Mar 20, 2003 | 03:12 AM
USDM 4G VTEC's Avatar
new rotors.. lifetime warrant are $19 ea from pep boys!
Old Mar 20, 2003 | 03:16 AM
Default Re: major shaking ...... (USDM 4G VTEC)
thanx
Old Mar 20, 2003 | 06:42 AM
Louie B.'s Avatar
Hondas seem to be famous for this... I warped the front rotors on my '97 EX 4 times in the 4 years I had it. Haven't really had a problem in my '91 yet.
Old Mar 20, 2003 | 12:32 PM
allicedout's Avatar
yo g, u need to replace the rotors cause there warped, BUT thats not all. why did ur rotors warp????? More then likely cause u have ceased calipers and therefore creating excesive heat which in turn warped ur rotors. So before u go out and spend ur dollars on rotors make sure u get the calipers serviced as well. Hope this solves ur problem.
Old Mar 20, 2003 | 12:35 PM
Ef Whore's Avatar
Default Re: major shaking ...... (allicedout)
ceased calipers?....never heard of that....
Old Mar 20, 2003 | 12:49 PM
pervytheclown's Avatar
yo, yo, yo...word to yo motha'!
Old Mar 20, 2003 | 12:55 PM
wickedEFguy's Avatar
derek
They might be warped but also his wheels might not be balanced, either way you gonna have to spend money
Old Mar 20, 2003 | 04:33 PM
95 LS's Avatar
Default Re: major shaking ...... (Ninja_Jc7)
That guy was right about the caliper essentially not completely letting go of the rotor and causing excessive heat and warping your rotor. When you replace your rotors check to see if the little dowels (the metal tubes with the accordion rubber boots) that the bolts run through to bolt to your knuckle move freely. If not knock them out, sand off any rust lube, them up, and install them back in and make sure they slide freely. Also make sure the accordian boots aren't torn or missing because water will get in there and eventually cause the same thing to happen again. Most of the time when peoples rotors warp and the new ones warp again really soon after its because the slider isn't moving freely. We do this with every brake job at our shop and its a good idea to do this every time you replace your pads. Just a little preventative maintenance. Take it easy
-Jacob
Old Mar 20, 2003 | 06:09 PM
EF Two's Avatar
Default Re: major shaking ...... (95 LS)
Get some Brembo blanks and some EBC green brake pads
Old Mar 20, 2003 | 06:17 PM
dgonzals's Avatar
From: The Land Of Car Thieves/Rising Gas Prices Daygo, CA, US
Default Re: major shaking ...... (DX_Tuner)
dang, my car is doing it too, just at high speeds when i try to slow down, have to get mine checked out. I think I am going to do the upgrade if that is the case 90-93 braking system here I come....
Old Mar 20, 2003 | 06:19 PM
bluecrxsi's Avatar
mine did the same-till i put on new slotted rotors/performance pads.
GSRacer1
Mar 10, 2011 11:54 PM
Chez'sExCoupe
16
Jan 14, 2006 09:28 PM
HondaEconoBox
11
Oct 29, 2005 12:18 AM
mechengine
Apr 3, 2004 10:48 PM
crx1856
Jul 2, 2003 01:11 PM
