JDM H22A auto into 93 Accord EX auto???
Old Mar 19, 2003 | 08:59 PM
PliggityPB's Avatar
Default JDM H22A auto into 93 Accord EX auto???
I was wondering if anybody has done this before? I'm looking for information regarding wiring. I am in the process of dropping this motor in for somebody and I noticed that the stock Accord tranny is a 4 solenoid automatic, where the Prelude tranny is only a 2 solenoid auto.
My questions are these:
1. Do I use the H22A wiring harness and just plug in the JDM ECU? And if so, what CEL lights, if any, will arise??
2. Are there going to be additional wires that I am going to have to run or extend in order to shut off any CEL lights?
Any information is appreciated. Please let me know. Thank you, Pat.
Old Mar 20, 2003 | 01:31 AM
KTeller8's Avatar
Default Re: JDM H22A auto into 93 Accord EX auto??? (PliggityPB)
just use the jdm ecu and it will work fine i am sure
worry bout CEL 's after you get them
Old Mar 20, 2003 | 05:06 AM
carolinaACCORD's Avatar
Default Re: JDM H22A auto into 93 Accord EX auto??? (KTeller8)
yah, use the jdm ecu and you SHOULD be fine.
Old Mar 20, 2003 | 09:54 PM
PliggityPB's Avatar
Default Re: JDM H22A auto into 93 Accord EX auto??? (carolinaACCORD)
Alrite, thanks for that.
I found out today that the wrong tranny was sent with the engine, which takes away the huge worries I was having...turns out they sent an auto 2nd gen Teg B16 tranny...
So now my questions are these...using the H22A tranny, do I use both pass. and drive side Accord axles? and, with the JDM H22A, it has an internal coil...the stock 93 Accord has an external...with the stock Accord harness plugged in...what do I need to do to make the JDM H22A distributor work properly? Somebody told me nothing, the ecu will make up for wires that are not being used? Please help. Thanks again in advance. Pat.
Old Mar 20, 2003 | 11:05 PM
KTeller8's Avatar
axels are all accord
use those
i dont know bout the dizzy
i had to swtich mine
Old Mar 21, 2003 | 08:47 AM
Luisito825's Avatar
you can run the accord ex auto tranny ECU with the h22 auto tranny. but you'll redline sooner. Also i noticed its a little better on the freeway...
Old Mar 21, 2003 | 03:32 PM
PliggityPB's Avatar
Default Re: JDM H22A auto into 93 Accord EX auto??? (buss)
Ok, even though the stock Accord axle on the drive side runs from tranny to hub? Isn't that gonna create hella torque steer??
Anyways, again, any help is appreciated.
And we're thinking that we may be needing to pick up a H22A distributor from a 97-01 Prelude with the stock external coil....is that assumption correct??? Thank you, Pat.
Old Mar 23, 2003 | 03:15 PM
Unknown Member's Avatar
My brother has an Automatic h22 accord.....thing is sick
Old Mar 23, 2003 | 05:29 PM
macd7919's Avatar
Default Re: JDM H22A auto into 93 Accord EX auto??? (JDM IS RICE)
H22 in an accord is nice....BTW If your brother wants a header already made for the accord h22 swap I have a kamikaze 4-1 and I'm local to Bowie...mail me at macd7919@netscape.net if interested
Old Mar 23, 2003 | 07:24 PM
KTeller8's Avatar
Default Re: JDM H22A auto into 93 Accord EX auto??? (macd7919)
http://www.accordinglydone.com/tech.php?ID=57
will show you how to make it from one to the other dizzy
HandoEX
Mar 29, 2006 07:23 PM
accordhyperwhite
Jul 14, 2004 08:19 AM
accordlude
Jan 22, 2004 09:18 AM
hungy
Dec 25, 2001 07:16 PM
