need help on zc tranny install in crx
Old Mar 19, 2003 | 08:25 PM
camboMONK's Avatar
Default need help on zc tranny install in crx
Can someone please tell me what exactly I need in order to install a zc tranny in a 89 crx si. Any help will be deeply appreciated.
Old Mar 20, 2003 | 06:06 AM
jlicrx's Avatar
Default Re: need help on zc tranny install in crx (camboMONK)
if you are talking about ZC tranny with the Si engine, it won't work - tranny will bolt to engine, but ZC uses an intermediate axle shaft which won't bolt to the Si block - i suppose you could have custom axle made for the driver's side - you can put the ZC 1 thru 5 gears in the Si tranny with the Si final drive and have the best of both worlds.
Old Mar 20, 2003 | 06:16 AM
wronghand's Avatar
Default Re: need help on zc tranny install in crx (jlicrx)
Actually the intermediate shaft will bolt up to the Si block. The tapped holes are there. Keep in mind that the awd wagon used an intermediate shaft. As far as the items you will need. You will need the ZC int. shaft and either ZC or 90-93 teg axles. That should be about it.
Old Mar 20, 2003 | 04:18 PM
camboMONK's Avatar
Default Re: need help on zc tranny install in crx (wronghand)
thanks alot guys. that's great info.
loudes13
Jun 9, 2009 07:19 PM
jeffinlimbo
Dec 8, 2004 05:15 PM
3rdgenh22
Jul 13, 2004 07:22 PM
VELOCITY R
Sep 4, 2003 05:37 AM
honduh-guy
Feb 26, 2002 09:19 AM
