crx hf to b18a 88-89 what do i need
Old Mar 19, 2003 | 06:47 PM
pdiddyparsons's Avatar
Default crx hf to b18a 88-89 what do i need
i just got this motor for $250 i need everything any info on how to or where i can get a tranny cheap would be great!! dont know what tranny,knuckles,axles,wire harness to use. help
Old Mar 19, 2003 | 07:42 PM
Cvic90's Avatar
Default Re: crx hf to b18a 88-89 what do i need (lilparsons)
You need to use the HF engine harness, 90-93 intermediate shaft and axles. You can use any B-seres tranny. If the trans is a 90-91 or jdm cable, it will use the 90-91 clutch, the 92-93 trans will have a larger input shaft for the clutch. you also need a distributor, ecu, and I believe steering nuckles. I think the HF has the smaller axle shaft in the steering nuckle. This you can check with a B-series axle for the size during install. I also suggest getting a hasport mount kit. It fits great, I haven't had any problems from mine. You can get shift linkage from hasport or shorten linkage from any 90 and up integra.
Maireeka
Nov 9, 2008 04:27 PM
superbeastcrx
Nov 3, 2004 05:11 PM
alexsracing
Nov 1, 2004 05:22 PM
inline4
Oct 12, 2003 08:00 AM
hahagasdcrx
Mar 6, 2002 07:08 PM
