Need help asap.. puttin tranny on ZC, clutch wont go in
Old Mar 19, 2003 | 06:40 PM
drjondurst's Avatar
Default Need help asap.. puttin tranny on ZC, clutch wont go in
Im in the middle of doing my ZC swap.. got the flywheel switched over from the Si onto it. The clutch and pressure plate are just sitting on the flywheel not tightened. Isnt this clutch lever thing supposed to be able to move?
Old Mar 19, 2003 | 06:44 PM
7PSI CRX's Avatar
Default Re: Need help asap.. puttin tranny on ZC, clutch wont go in (drjondurst)
As you move that lever, the release bearing on the other side of the tranny should slide in and out.
It's not moving at all?
Try pushing the release bearing in by hand, maybe it's just too far out and got *cocked*.
Old Mar 19, 2003 | 06:52 PM
drjondurst's Avatar
Default Re: Need help asap.. puttin tranny on ZC, clutch wont go in (7PSI CRX)
Ok Ill try that.
Old Mar 19, 2003 | 07:10 PM
xjoe's Avatar
it should move freely if the tranny isnt connected to the motor ... if you have the trans bolted to the motor, it'd be pretty tough to pull up
sporty240
15
Sep 30, 2004 07:02 PM
phatrick2332
Mar 31, 2004 06:11 AM
Ronin Panda
15
May 11, 2003 05:05 PM
camboMONK
Apr 1, 2003 07:15 PM
