what throttle cable bracket to use for the y8 manifold swap?????
Old Mar 19, 2003 | 05:18 PM
fastcrxsi90's Avatar
From: the asshole of america..., upstate new york, USA
Default what throttle cable bracket to use for the y8 manifold swap?????
y8 intake manifold on an a6 head.
ive tried throttle cable brackets from:
97 accord f22
90 integra b181
92 civic d15b7
98 civic d16y8
87 integra d16a1
is there one that is even close? or do you have to make one? or do you need a different throttle cable? wtf?????
Old Mar 19, 2003 | 05:35 PM
Malgerus's Avatar
Default Re: what throttle cable bracket to use for the y8 manifold swap????? (fastcrxsi90)
Y8 throttle cable bracket flipped upside down
Old Mar 20, 2003 | 12:34 PM
Default Re: what throttle cable bracket to use for the y8 manifold swap????? (Mr. S)
ok thanks...im officially retarded!!!! i tried everything everywhich way except the y8 upside down. if i didn't waste more time messin with stupid ****...i dont know what id do. thanks
Old Mar 20, 2003 | 01:10 PM
1.8Tities's Avatar
Hey, i just got back sorry i didn't answer your IM. Yeah, you didn't read my old thread. I told you, you have to flip the bracket or if you dont want sitting up to high, you can get a strong aluminum with holes on each end and kind bend the other end so it will sit flat on the IM holes and use the other end to put your bracket upside down. WIth mine, i didn't flip it because it was sitting low enough that i can put my cable in.
Edit: I just checked my bracke and i did flipped down with my extended adapter with it.
[Modified by 4thGSi, 2:13 PM 3/20/2003]
eg6sy
Jul 11, 2012 10:53 PM
Project Dad
Mar 28, 2011 04:12 PM
4DRmafia
30
Nov 10, 2008 11:59 PM
ekx4
Jun 1, 2007 10:38 AM
