B20 into EK wiring woes: OBDI ecus look for crank fluctuation sensor?
Old Mar 19, 2003 | 03:58 PM
DevinW's Avatar
Default B20 into EK wiring woes: OBDI ecus look for crank fluctuation sensor?
Hi,
I have a 96 Civic with a '99 B20Z swap using an OBDI LS ecu. Questions:
1)Do the stock '96 Civic wiring harnesses have a connector to plug into the CKF (crank fluctuation) sensor?
2)Will the OBDI LS ecu look for this sensor, or give a CEL if it is not plugged in?
Thanks for you help...wiring is defitely a pain in the butt if you're not sure what you are doing...
Old Mar 20, 2003 | 08:43 PM
StorminMatt's Avatar
Default Re: B20 into EK wiring woes: OBDI ecus look for crank fluctuation sensor? (DevinW)
The crankshaft speed fluctuation sensor is purely an OBDII thing. OBDI ECUs don't look for it.
Old Mar 20, 2003 | 09:55 PM
powerfulperformance's Avatar
Default Re: B20 into EK wiring woes: OBDI ecus look for crank fluctuation sensor? (StorminMatt)
Don't even work about that. I just did a swap in my ek and left that cable out..
[Modified by powerfulperformance, 10:55 PM 3/20/2003]
sureshot007
Aug 31, 2020 07:05 AM
grimybill
Honda CR-V & Element
Jul 29, 2013 12:30 PM
FRKWOO
18
Jul 15, 2011 06:36 AM
vtec4max
May 25, 2007 08:41 AM
lastpunkinline
Feb 28, 2006 06:03 PM
