would you hate me if i put miata rims on my rex
this guy is sellin me a set of 16 inch 7 inch wide 2001 miata rims, they look sweet in my opinion, i know ill get hated some but how much?
Make sure the offset is correct because I tried to use a set of 90-91 miata wheels and they didn't fit right onto the hub of my crx. But on the other hand, things might be different since you're talking about the 2001 model.
i want a set of the first gen miata mesh wheels.. like 10-12 lbs, 14x6..
1) OEM 16" Miata wheels are 16x6.5
2) The centerbore is diff on earlier gen. Miata wheels, and that's why it doesn't fit Civic/CRX. Again, not sure about 2k1s.
o yeh, are you sure they are 16 x 6.5 , cuz the tires on them are 205/40/16 isnt that 7 in wide? oh, if they are 7 they will rub cuz im slammed, but how could i make them not rub, roll my fenders? im raisin it bout .5 or 1 inch when i put them on w/ my new shocks, 89 accord fronts for more travel! yeahhh
The tires are 205/45/16, and I am sure they are 16x6.5
[Modified by fangtl, 11:59 AM 3/20/2003]
ok, i think rex offset is 34, im pretty sure it is, but i dont know what that is so it doesnt matter, but if it doesnt fit, what do i need to dremel or whatever. is it the middle little circle? like how some wheels have a center caP/? aahh jeez im stupid.
I personally like the little 14" 7 spoke "teeny RX7" wheels from about 94-95... They look great on CRX's and cars that want strock size wheels for autox.
Ahhhh yes....
Ahhhh yes....
Dude, centerbore is not the same as offset. Anyway, if it doesn't fit, open up the centerbore (or as you put it, "the little middle circle") of the Miata wheels to the size found on your CRX wheels.
BTW, I was just joking about the dremel, I wouldn't really recommend it unless you have really steady hands.
I had the miata wheels on my car that look like mini panasports. They where pretty nice and good for autoX.
I had problems with trying to fit the miata rims on my rex way back when... The center of the miata hub was smaller than the honda... I eneded up selling the rims... but to wonder, how did you guys fit the rims on...
ok im stupid, very stupid, what is the offset of wheels, and if the rex is 34mm i think....and miata is 40mm what does that difference mean?
just my .02
