What octane lvl?
Old Mar 19, 2003 | 11:52 AM
Jebus's Avatar
Default What octane lvl?
I just swapped a B16A2 and im wondering which level of octane i should use?
thanks
Old Mar 19, 2003 | 11:54 AM
Happyman's Avatar
Default Re: What octane lvl? (Jebus)
Premium
Edit: I think that's 91-93
[Modified by Happyman, 12:54 PM 3/19/2003]
Old Mar 19, 2003 | 11:57 AM
Silver Civic OH's Avatar
Default Re: What octane lvl? (Happyman)
Thats sounds right.
Old Mar 19, 2003 | 12:00 PM
jdmCHEF's Avatar
Premium
no question. thats all u should use
Jebus's Avatar
Default Re: What octane lvl? (Silver Civic OH)
damnit...now its gonna cost me a arm and a leg for fill ups...
you sure i cant use 87 or 89? will i lose power if i do?
Old Mar 19, 2003 | 12:04 PM
Happyman's Avatar
It'll run like ****. The level of your compression is what decides what octane. If you run lower octane then the fuel will ignite earlier which will set off your timing. Which could cause damage down the road. Just put out the extra 50 cents to a dollar and get premium. Or you could get Regular and spend money on octane booster.
Old Mar 19, 2003 | 12:06 PM
Jebus's Avatar
If it makes any difference im running a P72 GSR ECU...i guess thats another readon why i should run 91
Old Mar 19, 2003 | 12:08 PM
B16A2-EM1's Avatar
What is the exact Octane level to run for B16? What is recommended by Honda?
We have here
87
89
91
92
U ususally don't go any lower then 89. Is this to low?
Old Mar 19, 2003 | 12:55 PM
Jebus's Avatar
Default Re: What octane lvl? (B16A2-EM1)
my manual is for a 97 CX..and i cant find a online manual..thats why i asking
so far i looks like i need to run 91...
Old Mar 19, 2003 | 01:44 PM
Happyman's Avatar
Civic Si is recommended to run Premium by factory standards.
Old Mar 19, 2003 | 01:51 PM
oldB18EF's Avatar
run a minimum of 91
i run 93 or 94 in my B18 depending on how much sunoco feels like raping me
Old Mar 19, 2003 | 01:58 PM
careawholelot's Avatar
Default Re: What octane lvl? (WR93EG)
cali sucks the highest octane we can get is 91. damn environmentalist but i do know of a place near me were i could get 100 octane but that **** is $5 a gallon.
Old Mar 19, 2003 | 02:08 PM
B16A2-EM1's Avatar
Does anyone know the exact number???
Old Mar 19, 2003 | 02:34 PM
00MRSi's Avatar
On the fuel door on my SI it says "Premium fuel only". Octane levels vary depending on where you live in the country. California/COMMUNIST state seems to only get shitty 91 octane as the highest. Here in NY/NJ/CT Premium fuel is 93 octane. However Sunoco Ultra 94 octane is available. I use Ultra 94. I'd use the HIGHEST OCTANE available to you. Don't go below 91. You have a high compression motor. Your car will run like ****. (timing retarded, etc.). You should've know this before you swapped in the motor. Don't cry, just buy good fuel..
Old Mar 19, 2003 | 05:05 PM
Happyman's Avatar
Default Re: What octane lvl? (00MRSi)
Higher octane than is required will not make your car run better. Just get what is required and that's enough. Obviously if it says Premium then get Premium. I'm sure Honda took it into consideration that not every states Premium is the same.
phelpsj2
66
Dec 6, 2010 07:57 AM
Cvicex609
Honda Civic (2006 - 2015)
17
Dec 2, 2007 03:30 AM
plan B.
May 28, 2004 08:13 AM
E-lude78
Feb 19, 2003 03:14 PM
bryant
Jan 27, 2002 04:07 PM
