Polyfill
Old Mar 19, 2003 | 10:25 AM
JTCdudeman's Avatar
Master H Technician
Default Polyfill
I know crutchfield and all those ppl sell it... Is it worth it? I have a box made just under reccommended air space by .02 ft^3... The only reason I ask because it sounds good now is because I have my subs out waiting to do some custom crapet work as soon as I cna find and get some and because I am on dya 3 of my spring break cleaning garagwe and basement and I found a huge package of it just sitting in there... I am thinking about putting some in... How much if any shoudl I put and will this help a sealed box... I was low on room so went sealed... they r 10" subs so I figured polyfill woudl slow waves make it sound bigger... But the box is the right size almost and it sounds pretty good... Could use a lil more low end.... What do you guys reccomend... BTW, what I am cleaning has taken 30+ hours and needs about 40 more hours... 13 yrs f just thrwing it down there has left a pile so big from my family of 5 that you cna barely crawl through it to get out the garage door and its big.... Last weekend we filled up a 15ft by 6ft by 6ft dumbster al the way to the top and have another coming on friday... LOL.. no one has seen a mess like this... But once I am done, I have the rights to the garage for my LUDE...HAHA.. wokrs for me.. PLus I live on that floor and seeing it about 2x a week is just awful... Thnx guys...
Old Mar 19, 2003 | 12:12 PM
vteg's Avatar
New User
Default Re: Polyfill (JTCdudeman)
Just do it!!
I think subs sound fuller with some polyfill. Adding about 1 pound of poly per cube should be fine.
Old Mar 19, 2003 | 02:52 PM
t0p_sh0tta's Avatar
Default Re: Polyfill (vteg)
Can't hurt, go for it.
Old Mar 19, 2003 | 02:54 PM
ATF Kuk's Avatar
u can buy it from michaels craft store. u dont have to wait for shipping
Old Mar 19, 2003 | 04:16 PM
t0p_sh0tta's Avatar
Default Re: Polyfill (ATF Kuk)
read the post, he already has it.
Old Mar 19, 2003 | 05:08 PM
ATF Kuk's Avatar
Default Re: Polyfill (t0p_sh0tta)
see my *** (avatar)? kiss it
Old Mar 19, 2003 | 05:20 PM
t0p_sh0tta's Avatar
Awww... n00b hostility, so cute...
Old Mar 19, 2003 | 05:27 PM
ATF Kuk's Avatar
not noob hostility. if i was being hostile then u would know. i might have 30 posts, but i can still kick ur a$$
Old Mar 19, 2003 | 05:41 PM
JDMITR222's Avatar
ehhhwwww another Keyboard gangsta.
Old Mar 19, 2003 | 06:18 PM
xcathodex's Avatar
Default Re: Polyfill (JDMITR222)
hahahahahhahahahaha
and now to divert the topic a bit; what exactly is polyfill? and what does it do?
Old Mar 19, 2003 | 06:44 PM
JOMO
Guest
Posts: n/a
Default Re: Polyfill (xcathodex)
Old Mar 19, 2003 | 06:51 PM
t0p_sh0tta's Avatar
hahahahahhahahahaha
lol... basically it is the stuff that pillows and things of that sort are stuffed with (looks like cotton). It is used in boxes to slow the waves traveling in the box, making it sound more musical? It can also be used to compensate for haveing a box that is too small for your woofer.
Old Mar 19, 2003 | 06:58 PM
JOMO
Guest
Posts: n/a
do you just 'drop' it in the box or glue it to the sides?
Old Mar 19, 2003 | 07:27 PM
t0p_sh0tta's Avatar
Default Re: Polyfill (JOMO)
Usually it's stapled, but I guess spray adhesive could work. I don't know how it would hold up over time though.
Old Mar 19, 2003 | 07:44 PM
ATF Kuk's Avatar
is that the only thing u can do, crack jokes?
[Modified by ATF Kuk, 8:46 PM 3/19/2003]
Old Mar 19, 2003 | 07:49 PM
GSteg's Avatar
polyfill works for my application. when i built my E15K ported box, it was only 2.6 cubic feet after displacement. damn small so i added 2lbs of polyfill to it. there are noticeable differences (well at least in my application)
Old Mar 19, 2003 | 08:26 PM
koco's Avatar
Some of the best high end speakers use polyfill and similar fillers. Just try it and see what happens. It's not critical how much you use.
It's the same stuff that's inside pillows; it's available at Wally Mart.
Old Mar 19, 2003 | 08:29 PM
JTCdudeman's Avatar
Master H Technician
Default Re: Polyfill (GSteg)
So did you just stuff it into your box or did you adhere it to the sides like described above... I have always seen it stuck in there and pulled apart so its fluffy... But ive only seen 2 applications of it... I think I will go with adhereing if thats what you guys reccomend... It was so cool going wtf is this and reading POLYFILL... I was like NO WAY....BAD ***... Then I asked for opinions and we r here now!
Old Mar 19, 2003 | 08:30 PM
vteg's Avatar
New User
Default Re: Polyfill (koco)
I never stapled or glued in my poly. If you use one pound per cube, the box will be pretty full of it.
Of course these were sealed boxes. In a ported box then you have to keep it inside, so this could be important.
[Modified by vteg, 9:31 PM 3/19/2003]
Old Mar 19, 2003 | 08:39 PM
JTCdudeman's Avatar
Master H Technician
well... I am in the same boat with sealed.. I guess I will either get some carpet in a day or so and dot eh whole install again or just polyfill and replace.. My system sounds shitty w/ no bass... Damn those bass blockers...
Old Mar 20, 2003 | 01:31 AM
JOMO
Guest
Posts: n/a
what?
Old Mar 20, 2003 | 05:14 AM
t0p_sh0tta's Avatar
Bassblockers = Crossovers
They get attached to the speaker wire somewhere before the speaker. I've never used, or heard them, but they supposedly work very well.
Old Mar 20, 2003 | 09:01 AM
JOMO
Guest
Posts: n/a
i always thought crossovers before the speaker 'enhanced' the bass, made it sound more refined
those are called 'in-line' crossovers right?
Old Mar 20, 2003 | 09:09 AM
JTCdudeman's Avatar
Master H Technician
Honestly I put bass blockers on all my speakers less than 6.5" ones so I protect them at high volumes... I have never blown a speaker fomr midbass, but low bass tears them to shreads... Plus, what purpose are my subs serving.... My setup: tweeters up forn with 5 1/4's in the door, 6.5's rear, and subs trunk.... That way I get my bass and my highs just right... It doesnt take expensive speakers or anything... I first used bass blockers in My JEEP wrangler... 2 speakers and a sub... You do the math... Gotta have power to those speakers right? I did miss a bit of my midbass in that, but you didnt notice it unless you got in a competition car and listened to the same thing....
Old Mar 20, 2003 | 09:42 AM
GroundZer0 336's Avatar
how much is poly fil, and if i put a pound in a .88 ft^3 sealed box will it take up like the whole damn box or what.
