zc in 89 crx dx
i got the tranny with the zc motor and i dont think the axle shafts from the acura 89 will fit into the disc brakes i think there a diffrent spline count any one else have the same problem?
I think he is trying to help you.
Maybe he doesn't know the answer to your question, but he's giving you a tip on how to find it. I personally don't know the answer either, but if you do a search you will probably find something out.
you need 90-93 integra axles
thanks xjoe this is what i was looking for, changing the knuckles i knew that i had to use integra axles but i found out they have diffrent spline count so maybe i can look for them in the junk yard thanks alot
correct ... but he may also need the si knuckles ... do a search, it'll help you out, the dx has a different spline count, so the integra axles wouldnt fit
EKCRX-Ihadastupidusername
12
Nov 23, 2005 03:36 PM
Throwdown
Mar 21, 2005 07:34 PM
mockujin
14
Nov 13, 2002 06:39 PM
