how to install DSM injectors
how do you wire 1g DSM 450cc injectors in a 88 crx Si obd-0. i know homemadeturbo.com has a tech article on how to install and wire the 2g saturated injectors but that wont work for me. any help...........
If you're going to use your stock seals, they'll have to bored since the DSM injectors are alot fatter than you honda OE's. I used a dremel and bored the inside out a little at a time and kept trial fitting the injector into the IM until the correct width was reached. Your stock harness should bolt right up to it, and since your nonOBD everything else is good 2 go.
[Modified by RAWB, 10:14 AM 3/19/2003]
You don't need to change any wiring to run DSM injectors in an OBD0 Honda. The seals may need some modification, but the OBD0 Hondas use the same type of injectors as the DSM (low impedance).
Sonny
jas0n
Dec 13, 2002 08:34 PM
