Are all B Series Axles Identical? Need Help.
Old Mar 19, 2003 | 06:16 AM
jaysonx's Avatar
Default Are all B Series Axles Identical? Need Help.
I have just swapped a JDM B20b into my 1993 delSol, and have run into a minor problem with my axles. Both the axles and the intermediate shaft are off a 1994 Acura Integra LS. The passenger side axle fits perfect, but when i installed the drivers side, the axle seems to be approx 2 inches too short. The splines barely make in into the hub when it is stitting on the balljoint. I was under the impression that all Integra / Civic B series axles are the same (minus ABS ones), so I have ordered a intermediate shaft off a delSol VTEC hoping that it will remedy the problem. The shaft hasnt arrived yet, but I am now starting to get concerned that the problem could be the axle itself being too short.
Can anyone give me any help with this?
[Modified by jaysonx, 10:16 AM 3/19/2003]
Old Mar 19, 2003 | 06:43 AM
BoostedsiR's Avatar
Default Re: Are all B Series Axles Identical? Need Help. (jaysonx)
I just posted that I need axels because I snapped mine at the track but the reason you are having a problem is because on a b18 the axles are one male and one with a female end I know that the b16 is 2 males so if you were to do this you would have to get the right intermediate shaft I hope I somewhat explianed it to you but shouldnt the axles be two long not short that is ******* strange for a delsol
good luck
Old Mar 19, 2003 | 12:31 PM
jaysonx's Avatar
Default Re: Are all B Series Axles Identical? Need Help. (BoostedsiR)
TTT
any other thoughts?
jdmjackson
Feb 14, 2013 03:52 PM
rdeezy78
May 8, 2009 01:47 AM
grg9988
Mar 7, 2008 04:11 PM
DTS
Oct 10, 2006 10:55 AM
McDade
Sep 1, 2003 07:49 AM
