What oil do u use?
Old Mar 19, 2003 | 04:08 AM
Chubs's Avatar
Default What oil do u use?
What oil do u use? For the F22x, h22a's, ect....
Old Mar 19, 2003 | 04:31 AM
m0t0rhead's Avatar
Default Re: What oil do u use? (Chubs)
You can use any oil as long as you change it every 3000 miles. The results will be just as good. I've used plenty of different brands and weights....
Cuz I'm a freak, I prefer to use 5w30 mobil 1 full synthetic which is expensive... but on the dyno you get a couple extra ponies over the standard 10w30
Old Mar 19, 2003 | 04:45 AM
TypeSH's Avatar
Default Re: What oil do u use? (Escobar)
f22b1, 164k miles, i use valvoline maxlife 5w30.
I initially was using 10w30 but switched to 5w30, got a lil better gas mileage and figured its ok since I'm in sunny CA which is warm most of the year.
Old Mar 19, 2003 | 06:01 AM
KGAccord's Avatar
Default Re: What oil do u use? (CCS)
mobil 1 5w-30 winter/ 10w-30 summer in the h22
Old Mar 19, 2003 | 06:58 AM
accordexchange's Avatar
10w 30 castrol syntec on my ride!!
i'm also using 10w30 for my boosted accord-either castrol or mobil1...
Old Mar 19, 2003 | 08:29 AM
ApexiAccord's Avatar
Default Re: What oil do u use? (accordexchange)
mobil 1 supersyn 10w-30
Old Mar 19, 2003 | 09:27 AM
carolinaACCORD's Avatar
Default Re: What oil do u use? (ApexiAccord)
5W30 Castrol GTX
Old Mar 19, 2003 | 09:36 AM
Stew Pidasso's Avatar
Default Re: What oil do u use? (carolinaACCORD)
5W30 Castrol GTX
[Modified by Stew Pidasso, 1:36 PM 3/19/2003]
Old Mar 19, 2003 | 03:46 PM
Broman78's Avatar
Default Re: What oil do u use? (Stew Pidasso)
penzoil 10w-30
Old Mar 19, 2003 | 03:50 PM
5LuGinTeg's Avatar
Default Re: What oil do u use? (Broman78)
any kind of 5w 30 thats what honda recomends
Old Mar 19, 2003 | 04:13 PM
One2chi's Avatar
Default Re: What oil do u use? (ScrewD07)
99 cent store mobil 10w30
Old Mar 19, 2003 | 07:08 PM
Baltz's Avatar
Default Re: What oil do u use? (One2chi)
royal purple 5w30...cause everything thing that will restore engine life is needed. I have 197,000 miles on mine and I have to keep the engine running for another 4-5 months until it comes time for the swap.
Old Mar 19, 2003 | 07:42 PM
iam7head's Avatar
Default Re: What oil do u use? (4th gen accord)
Pen. 10w30..pretty cheap..okay quality
Old Mar 19, 2003 | 07:57 PM
89_LXi's Avatar
Heheh....I don't think you need to worry about that too much. Come on it's a Honda, have some faith!
I use Mobil 1 synthetic 10w-30. Always worked great, so I'll stick with it
Old Mar 19, 2003 | 09:35 PM
Chubs's Avatar
Default Re: What oil do u use? (89_LXi)
Yeah Mobil 1 full synthetic all the way!!! My oil level dropped from full to empty in about 6000miles thats not right is it????
Time for a rebuild?????
Old Mar 20, 2003 | 09:49 AM
hs2000's Avatar
I use mobil 1 10-30 all year. I lose about half a quart between oil changes, I have no idea wether that is normal or not, I hope it is.
Old Mar 20, 2003 | 09:57 AM
Kn33gr0W's Avatar
Uhh, well...no that isn't good but neither is going 6000 miles without a change.
Old Mar 20, 2003 | 10:16 AM
accord91h22's Avatar
Default Re: What oil do u use? (Kn33gr0W)
Hell yeah Royal Purple is the ****! If you can get a good deal on it , usually its like 7-9/quart . If ya search good enough youll find it for like 4.75/quart. Thats what Ive been payin here. They say you actually gain hp from this oil, its in their brochure. Dyno tested. The shop I get it from uses it in their drag car. I HIGHLY recommend this oil!! Plus it really ***** with ppl when they see ya putting purple oil in your ride.
Old Mar 20, 2003 | 12:17 PM
Broman78's Avatar
Default Re: What oil do u use? (accord91h22)
I was reading were the royal purple isn't good for everyday driving cause breaks down to fast but is great for the track. I'll try to find the article.
Old Mar 20, 2003 | 12:23 PM
greensleeper's Avatar
5W30 Castrol GTX
works fine. mid priced.
Old Mar 20, 2003 | 07:01 PM
import palace's Avatar
it depends on you location in the country wether your weather is mostly hot year round etc...and how you drive also has to be considered.
Old Mar 20, 2003 | 07:14 PM
jweller's Avatar
Default Re: What oil do u use? (import palace perf)
5w30 in the winter 10w30 in the summer. whatever full synthetic is on sale when I buy it
Old Mar 26, 2003 | 12:02 PM
Default Re: What oil do u use? (jweller)
But if you change the royal purple every 3000 miles you dont have to worry about that.
Old Mar 26, 2003 | 12:37 PM
Chiovnidca's Avatar
I use whatever I can scrounge up around the shop. A half quart here, a half quart there. I don't worry too much about mixing different brands or weights. I just use a new filter and change it every 3-4k.
Old Mar 26, 2003 | 01:51 PM
Mocky57's Avatar
Default Re: What oil do u use? (TurboD16Chiovnidca)
mobil one
