99 Accord - use injector cleaner in gas?
Old Mar 19, 2003 | 01:06 AM
georgeda's Avatar
Default 99 Accord - use injector cleaner in gas?
What is Hondas recommendation for using an additive in the gas occasionaly to clean injectors?
Old Mar 19, 2003 | 10:52 PM
KwikSilverACC's Avatar
Default Re: 99 Accord - use injector cleaner in gas? (georgeda)
I put some in sporadically , i would say i do it like once a month
Old Mar 19, 2003 | 10:53 PM
EXV62000's Avatar
I do not think Honda recommends using injector cleaner if I am mistaken. They say as long you keep up your oil changes and use the proper gasoline rating, there is no need. There are additves in the motor oil & gasoline already that have the same effect as those found in all of those rip off injector cleaners. Just do all the maintence on time every time, and you will be fine.
Old Mar 20, 2003 | 09:22 AM
iam7head's Avatar
Default Re: 99 Accord - use injector cleaner in gas? (EXV62000)
once a while, on my beater as well as my accord
Old Mar 20, 2003 | 11:09 AM
95sihb's Avatar
Default Re: 99 Accord - use injector cleaner in gas? (iam7head)
the guy that posted 2 posts above me is right. Gas manufactors already add there own cleaners and adatives to gas , so they claim to keep your fuel lines, fuel injectors, and combustion chamber cleaner, then if they didn't use any adatives to there gas.
example........chevron they use techcron....
i really dont use anymore adatives or cleaners, if i dont have to if you really want to clean your fuel injectors out good, pull them out and clean them by hand, same for fuel lines( replace is better ) and fuel filter.
your car should be fine even if you add more adatives but i think i would be wasting money i would just rather send it on higher octain. thats what i think
[Modified by 96accordex, 12:25 PM 3/20/2003]
Old Mar 20, 2003 | 11:13 AM
Baltz's Avatar
Default Re: 99 Accord - use injector cleaner in gas? (96accordex)
the guy that posted 2 posts above me is right. Gas manufactors already add there own cleaners and adatives to gas , so they claim to keep your fuel lines, fuel injectors, and combustion chamber cleaner, then is they didn't use any adatives to there gas.
i really dont use anymore adatives or cleaners, if i dont have to if you really want to clean your injectors out good, pull them out and clean them by hand, same for fuel lines( replace is better ) and fuel filter.
your car should be fine even if you add more adatives but i think i would be wasting money i would just rather send it on higher octain. thanks what i think
This guy is exactly right. I asked my dad if I needed to buy some for my car and he said that all the gas stations add it in there gas already (or supposedly they do) so basically I just need new injectors (197,000) miles on a 13 year old car, yeah definately need new injectors
hondaracin24
Feb 7, 2005 04:50 PM
boltnut
Jan 10, 2005 04:11 PM
EK45VTi
10
Sep 21, 2004 07:03 PM
georgeda
Mar 8, 2003 08:02 AM
99Interlude
Jan 16, 2002 07:24 AM
