Which O2 sensor is Primary?
Old Mar 18, 2003 | 07:29 PM
SuperJay's Avatar
Default Which O2 sensor is Primary?
I'm gonna do my B16 swap soon and was wondering (since the wire harness was hacked on mine) which O2 sensor on the Exhaust Manifold is the primary and which is the secondary, I'm assuming the one closest to the timing belt is Primary, is this correct? thanx.
Old Mar 18, 2003 | 09:37 PM
spun Vtec's Avatar
Default Re: Which O2 sensor is Primary? (SuperJay)
doubt anyone in here is going to know try eg civic
Old Mar 18, 2003 | 09:38 PM
EG8R's Avatar
There should only be one O2 sensor.... Unless you have OBD2.
Anyone else agree?
Old Mar 19, 2003 | 03:23 AM
biggdogg's Avatar
what year car is the swap going into would help. if it`s a 88-91 it will be the one already there . it has a white or clear plug . the 2nd is a green plug
Old Mar 19, 2003 | 03:47 AM
RuffRhyno's Avatar
Do a search, there is plenty of info on it. All of these replies are wrong, though.
If the swap is OBD0 and going into a 88-91 Civic/CRX, you will be using the JDM PR3 or PW0 ecu. They look for 2 oxygen sensors. On your harness that goes to the ecu, C16 is the stock primary O2 sensor. You have to add a wire to pin C8 for the secondary O2 sensor.
And yes, you are correct about which O2 sensor is the primary one. It is the driver's side O2 sensor that is primary, and the passenger side is the secondary.
Good luck
Old Mar 19, 2003 | 05:09 AM
biggdogg's Avatar
Default Re: Which O2 sensor is Primary? (RuffRhyno)
LIKE I SAID! clear or white one is primary and the green plug is 2ndary . jeeeeeeeeez
Old Mar 19, 2003 | 02:05 PM
evo's Avatar
evo
New User
He mean O2 sensor on the Exhaust Manifold , cycliner 1-4 primary white wire, 2-3 secondary.
The car feel faster when i had wired it incorrectly. strange??
Old Mar 19, 2003 | 04:39 PM
SuperJay's Avatar
Default Re: Which O2 sensor is Primary? (evo)
Evo, thank you, That is all I was askin for. Obviously, the white one is primary, I knew that. but the manifold I got has the plugs cut off and I wasn't sure which one was which on the manifold. (and I did do a search smart *** RuffRhyno)
[Modified by SuperJay, 5:45 PM 3/19/2003]
[Modified by SuperJay, 6:05 PM 3/19/2003]
90efzc
Jun 5, 2011 06:19 PM
gtpilot
Dec 12, 2002 12:27 PM
creuger
Nov 15, 2002 07:11 PM
