Anything I could use from 90-91 HF motor on my ZC?
Old Mar 18, 2003 | 07:15 PM
c for sea's Avatar
Default Anything I could use from 90-91 HF motor on my ZC?
A friend of mine bought a hf with a blown motor. he put a b16 in his rex and I've got a 90 crx dx. I want to go with a ZC. Could I use anything from his motor? I know i can use the exhaust mani later on when i go turbo but it has a crack in it. please reply. thanks.
Old Mar 18, 2003 | 07:32 PM
HF2ZC's Avatar
Default Re: Anything I could use from 90-91 HF motor on my ZC? (c for sea)
You could use the TPS (throttle position sensor) and probably the engine wiring harness with some modification. The injectors will probably also work.
Old Mar 18, 2003 | 08:50 PM
c for sea's Avatar
Default Re: Anything I could use from 90-91 HF motor on my ZC? (HF2ZC)
thanks.
Old Mar 18, 2003 | 09:08 PM
HF2ZC's Avatar
n/p
You may also be able to use the flywheel, clutch, and pressure plate if you need to.
Old Mar 18, 2003 | 10:20 PM
audioroach's Avatar
This info is of good use to me as well.....I have an 89 hf and want to swpi in a
D16a6.....can I use the intake and TB? I allready have a pm6 computer and si
tranny aany other goodies I need or can reuse?
Old Mar 19, 2003 | 06:14 AM
CRzex's Avatar
New User
Default Re: Anything I could use from 90-91 HF motor on my ZC? (audioroach)
I belive you can use the HF Distributor for the MPFI swap.
Old Mar 19, 2003 | 06:52 AM
audioroach's Avatar
Default Re: Anything I could use from 90-91 HF motor on my ZC? (CRzex)
I belive that both the HF and Si are MPFI already.
Old Mar 19, 2003 | 08:49 AM
spun Vtec's Avatar
true they both are
Old Mar 19, 2003 | 05:38 PM
CRzex's Avatar
New User
So he can use the distributor for a MPFI swap on his DX.
Old Mar 19, 2003 | 10:56 PM
spun Vtec's Avatar
yeah but he's going with a zc so he cant use it anyways
liquidoblivion
13
May 19, 2011 12:07 PM
:mR. PotAtO heaD:
14
Dec 5, 2005 01:58 PM
iwouldHITit
Dec 29, 2002 06:24 PM
paRRRker
Aug 7, 2002 07:40 AM
The Brown Kid
Apr 1, 2002 12:18 AM
