Building a B/VTEC need info?
Old Mar 18, 2003 | 06:55 PM
ITR607's Avatar
New User
Default Building a B20/VTEC need info?
hi
i need some info on what piston and rod ratio's where used in your build and any other info you can provide. If a B20B or B20Z is better i have a ITR head already bore to 84.5
mm the head is done just need info on all the other stuff ...
wiring
mounts
oil lines
and so on..
thanks
[Modified by ITR607, 7:56 PM 3/18/2003]
Old Mar 18, 2003 | 10:19 PM
DOHCtorTHRUST's Avatar
Default Re: Building a B20/VTEC need info? (ITR607)
for wiring just use your stock one, same goes for your mounts..... for the oil lines get the ealrs t fitting and about 2-3 feet of oil lines(can remember what size...)
while your at it... get some JE or arias high compression pistons, you wont regret it
Old Mar 19, 2003 | 03:23 AM
J2turbo21's Avatar
Well if you swap out the pistons then the both b20's would be the same.Go with like a 11.5c/r and some eagle rods with upgraded rod bolts.1 thing to remember is that b20 sleeves are weak.Good luck.
dc4teg95
Nov 15, 2010 09:05 AM
redsolturbo
May 28, 2009 11:44 AM
oMek
Jan 10, 2004 09:23 AM
done
Oct 3, 2002 06:17 AM
MrFatBooty
Nov 29, 2001 01:08 PM
