JDM front lights
I bought my car with a JDM front, I tried to put the brites on and nothing happened...so I got out of the car to realize that the lights on the inside weren't on (ones pointed at in pic) I guess burned out, the outside lights are on but are they on constantly? Im just wondering what kind of bulbs I need to buy or if the guy rewired the car so that the outside lights are always on...I know kinda confusing but Im comming from 60-70's cars with just one set of headlights, thanks everyone
Oh and thats not my car, just a sweet pic I had on hand
[Modified by TerribleOne, 6:51 PM 3/18/2003]
Moving in order from outer-most to inner-most:
- turn signal/hazard: should only flash when the turn signal or hazard lamps are on
- low-beams: should be illuminated anytime the headlights are on, including when high-beams are also on
- high-beams (yellow arrows in picture): should be lit anytime high-beams are on (obviously), use an H1 bulb, also in this lamp are the city lights which should be lit anytime parking lights or headlights are switched on.
- fog lamps: should be lit anytime foglamp switch is on and headlight switch is in the parking or low beam position.
