Old Member New Name - Doing Brake Work on 2000 EX
OK I started doing the brakes on my ex(no rear disc) . I ran into a problem with the front rotors . After I finially managed to break loose the philips screws in the hubs (whos Idea was it to put those there?) I was still unable to remove the rotors . I have never done brake work on a honda before so I am kinda learning as I go . Is there any special tool I need to remove the rotors or is there a step I am missing ? ? ? ? ? ?
if the caliper is completely off and the two screws are off u should be able to yank of the rotor...i had no problem on my 99 ex when i did my brake job
Thanks I wasn't sure if I needed a something else to remove the rotor . Also the philips head screws . they are taking a beating from the impact tool I am using . Do I go to honda to get the replacements or is there another place I can go to get them . I tried Pep Boys and Napa but they just looked at me like "HUH"
u should be able to get them at Pepboys or Autozone OR Midas.
Oh, and if your screws took a beaten u should replace them.
b20acura
26
Aug 29, 2011 08:03 PM
BiG ChOr!Zo
Jul 5, 2010 02:57 PM
