Engine Trouble Need Help!!!!!!!
Old Mar 18, 2003 | 11:37 AM
NtgraTrboWanaB94's Avatar
Default Need Very Urgent Help ASAP!!!!!!!! ON THE DOUBLE!!!!!! GOING CRAZY :mad:
I just got my car back from being fixed from a tragic incident with my motor. Since it's been fixed my car lets out a large puff of blue smoke (oil) when the v-tec kicks in at 4,000 rpm's and the so called noise of the valves opening at 6,000 rpm's doesn't happen.
If anybody knows what the hell I'm trying to say I am all open to suggestions. It's hard to have to read the problem rather than see it with your own eyes.
[Modified by NtgraTrboWanaB94, 3:43 PM 3/18/2003]
[Modified by NtgraTrboWanaB94, 4:04 PM 3/18/2003]
Old Mar 18, 2003 | 11:58 AM
Default Re: Engine Trouble Need Help!!!!!!! (NtgraTrboWanaB94)
I hate my car anybody want it.
Old Mar 18, 2003 | 11:59 AM
Oh yeah and that whole acura is the **** deal is a load of crap.
Old Mar 19, 2003 | 06:12 AM
Any help would be nice right about now! Any reply would be nice even if you dont know.
Old Mar 19, 2003 | 10:00 AM
p1ccoloz's Avatar
relax its all goiong to be ok, i dont know you prob but i hope you get it fixed
Old Mar 19, 2003 | 10:08 AM
NeoGSR's Avatar
Default Re: Engine Trouble Need Help!!!!!!! (p1ccoloz)
first of all, what did you do when you "fixed you engine"
i didn't know the valves were closed until 6,000 rpm's seems like it'd be really hard to drive w/o the valves opening....
vtec engages at 4,400 not 4,000
you really didn't explain anything in detail, get some facts straight before you make an *** of yourself
i think you should sell your car because you have no idea what you're saying, buy a bicycle
[Modified by NeoGSR, 1:10 PM 3/19/2003]
Old Mar 19, 2003 | 10:18 AM
JimBlake's Avatar
Default Re: Engine Trouble Need Help!!!!!!! (NeoGSR)
Since its a VTEC, I bet he's talking about the secondaries (IAB)...
Old Mar 19, 2003 | 10:49 AM
Default Re: Engine Trouble Need Help!!!!!!! (JimBlake)
Excuse me, i mean the secondaries do not function properly for some odd reason, is that better to understand NeoGSR.
I am sorry to say that the work i had done to my motor was a result of the intake taking on water and bending two of my rods and damaging two of my pistons. I would have liked to have got a new motor but money was the problem and i needed a car, so i had somebody fix the motor. But now it has been brought to my attention that he has never worked on many hondas and he thinks that v-tec is some kind of fancy word that they put on the valve cover.
Old Mar 19, 2003 | 11:12 AM
I am making this reply to keep this topic near the top so you people will read it.
Old Mar 19, 2003 | 02:54 PM
Well you guys are not leaving me with alot of ideas.
Old Mar 20, 2003 | 04:02 AM
JimBlake's Avatar
... was a result of the intake taking on water and bending two of my rods and damaging two of my pistons... he has never worked on many hondas and he thinks that v-tec is some kind of fancy word that they put on the valve cover.
Knowing that, it could be so many different things. We can't see it from here, but if he screwed up with the rods & bearings, it should have problems all the time, not just when VTEC engages. So that leaves you with something not hooked up right in the VTEC system, or a leaky seal somewhere...
Also, something not hooked up right for your IAB valves.
Sorry to be so vague, but after that kind of work you just can't find a screwup over the web... I didn't want to post a reply that was meaningless, but you kept bumping...
The Helms manual has specific tests to do for each of these systems, if you want to start DIY stuff. Or since your mechanic didn't seem to know Hondas that well, find somebody who does.
Old Mar 20, 2003 | 12:10 PM
Well i am about take my car to a honda specialist. They have a diagnostic machine that they will hook my car up to, hopefully they will find the problem.
Old Mar 20, 2003 | 12:20 PM
carbuff2000gs's Avatar
What exactly did he do to fix your motor, what parts did he replace, could be a couple of things, rings,valves,are you burning oil? Could be a bad seal?Best of luck with your problem. Get a compression check when you do take it to a honda tech specialist
Old Mar 20, 2003 | 01:43 PM
Default Re: Engine Trouble Need Help!!!!!!! (carbuff2000gs)
Two new rods, claims to have a set of new piston rings, and whatever else you have to do to a flooded motor.
Old Mar 20, 2003 | 02:18 PM
BabyDaddy's Avatar
hydrolocked = bent valves
Old Mar 23, 2003 | 03:46 PM
well it turns out that my knock sensor wire was hooked up to the wrong sensor, it was hooked up to the sensor underneath my intake manifold. And the wire for that sensor was just dangling, all this was confusing the ecu and it was sending the wrong message to the motor. My bud Paul (JRSCCivic98) and me got it hooked up right and then we realized that the knock sensor wasn't even there thus explaining why there was one wire dangling. Then i drove my car and everything ran better than normal except not having the knock sensor and i will get that soon.
So thanks for all the help guys
Miracle
Sep 1, 2006 10:16 PM
Trendy26
Oct 23, 2003 12:55 PM
CRITTERMATT
May 17, 2003 08:19 PM
Comp97GSR
Feb 27, 2003 02:49 PM
