Spoon N1 Axleback and various B-pipes...
Old Mar 18, 2003 | 11:00 AM
skafia's Avatar
25 Year Member
Default Spoon N1 Axleback and various B-pipes...
I know for sure it fits onto the OEM b-pipe, Type One Racing, and its own spoon b pipe, but are there any other b pipes that it would fit on?
I'm seeing if it would fit on an Apex N1 Catback B pipe.... Thanks.
Old Mar 18, 2003 | 11:43 AM
Mike M's Avatar
Founding Member
Default Re: Spoon N1 Axleback and various B-pipes... (skafia)
Vision B Pipe.
Thats It, unless the B Pipe is made as an OEM Replacement it won't fit.
Apexi, HKS, Tanabe, etc. all make the B Pipe sections different, if you get a Spoon n1 to bolt up to one I will bet it will not fit correctly and will be somewhat off (eithe to far back or out and at the wrong angle. it is also safe to say that the flange on the end of the pipe will not be the right one, as you need one similar to the one on a header which uses a Donut gasket. Most aftermarket exhausts use a Flat gasket and flange.
Old Mar 18, 2003 | 11:48 AM
01-1293's Avatar
Default Re: Spoon N1 Axleback and various B-pipes... (Mike M)
how much does a spoon B-pipe go for?
Old Mar 18, 2003 | 11:55 AM
Mike M's Avatar
Founding Member
Default Re: Spoon N1 Axleback and various B-pipes... (01-1293)
Too Much, and its only 60mm (Its about $400)
T1R is 63mm and is $325-375
Old Mar 18, 2003 | 12:15 PM
skafia's Avatar
25 Year Member
Do you have any T1R B pipes Mike M? I need to get rid of my blinging Apex Catback system anyway...
Old Mar 18, 2003 | 12:49 PM
b18cu's Avatar
t1r
Old Mar 18, 2003 | 01:06 PM
StinkyTofu's Avatar
My stock axle back bolts on to my N1 B-pipe. Since spoon designs their axle-back to fit an OEM B-pipe, i am sure it fits with your n1 b-pipe.
Old Mar 18, 2003 | 01:17 PM
ajchen's Avatar
call mike M RIGHT NOW. i just canceled my order for my t1r bpipe... i'll be using a stock ITR bpipe instead cuz i am mad poor. he should have one for you, $295...
Old Mar 18, 2003 | 01:31 PM
Leo's Avatar
Leo
Default Re: Spoon N1 Axleback and various B-pipes... (ajchen)
Will a TIR B Pipe bolt up to the stock cat? Any gains to be had with just the stock axle back on?
Old Mar 18, 2003 | 01:39 PM
Mikes01GSR's Avatar
Default Re: Spoon N1 Axleback and various B-pipes... (Cyborg Ninja)
Comptech B-pipe also works being it can fit oem muffler, and the axle-back works
with oem b-pipe. I also know it works cause it's the set up I'm running right
now!!!
Old Mar 18, 2003 | 01:49 PM
B2FiNiTY's Avatar
Yes it will. Do not know about gains though..
Old Mar 18, 2003 | 03:06 PM
Champ R's Avatar
Default Re: Spoon N1 Axleback and various B-pipes... (B2FiNiTY)
Quick question... if i run a JDM header/2.5" cat and want to use my stock muffler, which b-pipe could i use that still bolts up to the stock muffler, but has larger piping or fewer bottlenecks?
Old Mar 18, 2003 | 03:19 PM
B2FiNiTY's Avatar
Default Re: Spoon N1 Axleback and various B-pipes... (Champ R)
T1R
Old Mar 19, 2003 | 06:20 AM
ajchen's Avatar
not really a news flash, but for those who are interested.
comptech bpipes DO have the donut flange on the exhaust side, so you wont have any trouble bolting a spoon n1 onto it. this was discovered after i was told it wouldnt work, so i went and bought a stock ITR bpipe
Old Mar 19, 2003 | 08:16 AM
skafia's Avatar
25 Year Member
Default Re: Spoon N1 Axleback and various B-pipes... (StinkyTofu)
Can anyone else confirm this? This would save me from buying another B pipe...
Old Mar 19, 2003 | 09:23 AM
B2FiNiTY's Avatar
Lets just try it dude
Old Mar 19, 2003 | 09:27 AM
Mike M's Avatar
Founding Member
As I said, I wasn't 100% sure about the type of flange on Comptech's. It still does not mean that it will be a <u>Perfect</u> Fit when you try to bolt the N1 on.
wasanissanFL
Jan 23, 2017 10:01 AM
01-0720
Apr 6, 2008 11:15 AM
JCL
Jul 6, 2006 12:07 AM
mikkey1
Jun 9, 2006 02:13 AM
hatchattak
Sep 28, 2004 08:51 AM
