Heat Shield Painting
Old Mar 18, 2003 | 10:09 AM
Diamante's Avatar
Default Heat Shield Painting
I want to do something with the stock heat shield in my 97 Civic HX. It's rusty. Can i safely paint it with some hi-temp paint? How about if i removed it altogether. What will it hurt?
Old Mar 18, 2003 | 10:28 AM
leprechan117's Avatar
Default Re: Heat Shield Painting (Diamante)
get the extra high heat stuff, it 1200 degrees instead of 500, people do run without them, but obviously itll rase your engine bay temp. if you have a short ram or the such itll be sucking hotter air. my frind doesnt have one on his 94 si with a gsr, but he also has an aem cia
[Modified by leprechan117, 2:29 PM 3/18/2003]
Old Mar 18, 2003 | 12:58 PM
Patch's Avatar
Default Re: Heat Shield Painting (leprechan117)
I took mine off for a while, and the engine bay was definately warmer. I stripped all the paint off of the heatshield and used some 500 degree Low Gloss Black paint. I put a few coats on and its been about a month now, still looks great.
[Modified by CRX PAT, 4:58 PM 3/18/2003]
Old Mar 18, 2003 | 01:34 PM
Mr. Thunderlips's Avatar
I have done this several times...The only way to get it to stick is to use a wire wheel prior to paint to give the paint something to bite on to.
I've done it both ways...One with, and one without the wire wheel.
The wire wheel heat shield has looked the same for over a year now.
Old Mar 18, 2003 | 02:36 PM
Patch's Avatar
Default Re: Heat Shield Painting (ThunderLips)
I used a wire wheel on mine. Forgot to mention that.
patotas
Paint and Body
Oct 7, 2009 09:31 AM
MAFDARK
Jan 26, 2007 05:52 PM
blaster834
May 27, 2005 10:57 AM
G'd_up
Honda S2000
May 12, 2005 01:15 PM
h22a193
Sep 17, 2004 08:34 AM
