Putting bumpers on CRX 1989
Old Mar 18, 2003 | 09:55 AM
snoop_bealybob's Avatar
Default Putting bumpers on CRX 1989
Is it tough to put bumpers on a 1989 crx model? Has anybody ever done this before. I'm good under the hood, but never done any body work. I can't imagine it being too tough. Your opinions on the job/skill level would be greatly appreciated. Thanks.
Old Mar 18, 2003 | 10:03 AM
Outsane's Avatar
Default Re: Putting bumpers on CRX 1989 (snoop_bealybob)
Are you talking about a kit or a stock bumper?
Old Mar 18, 2003 | 10:14 AM
SC0TT's Avatar
It can be tough getting the bolts holding it on loose, I stripped a bunch. But after that, its easy.
Old Mar 18, 2003 | 12:07 PM
SteveeeO's Avatar
Default Re: Putting bumpers on CRX 1989 (cr-tegra)
the front bumper is really simple... unscrew the two bumper lights, take out the housing, I think the bolt is a 14mm... under the fender there should be 2 small screws holding it, unscrew those, pull it off... your done
haven't done the rear bumper, but I read you gotta take out the lights
Old Mar 18, 2003 | 01:28 PM
FullMetalJacket's Avatar
Default Re: Putting bumpers on CRX 1989 (SteveeeO)
takes me like 10 minutes to take or put on front bumper on a crx..theres 3 screws near the radiator...two screws each side where the bumper meats the fender..underneath the corner light on each side is one more screw that looks similar to the ones on radiator support....on the bottom of the bumper there is 2 10mm bolts...I rate this pretty easy to do..infact i took mine of yesterday in the rain...
Old Mar 18, 2003 | 02:20 PM
SteveeeO's Avatar
Default Re: Putting bumpers on CRX 1989 (FullMetalJacket)
isn't there 4 near the radiator? 2 on each side...
Old Mar 18, 2003 | 02:45 PM
ona hatch i think theres 4 in the middle ar the radiator...im pretty sure my crx only had 3 near my rad..i could be wrong
Old Mar 18, 2003 | 05:49 PM
Wow thanks for the replies. If it's good mechanically I'll pick it up. I'm just interested in Stock. Thanks again.
Old Mar 18, 2003 | 06:34 PM
turbohf's Avatar
i never take the bumper off like that. i remove the 2 10mm behind the blinker lights, the two screws in the fenders, and the couple 10mm under the bumper (for the splash shield thing), then pull...
fog raw
Dec 26, 2011 04:56 PM
kixcrx
23
Jan 1, 2009 07:06 PM
gsrpedro
Feb 28, 2007 08:23 PM
hbyrd8701
Jan 7, 2007 12:05 PM
eda6
Feb 23, 2006 05:30 PM
