Voltage slightly drops during idle
Old Mar 17, 2003 | 11:28 PM
96RS's Avatar
Default Voltage slightly drops during idle
What's up guys, I have a tech question. My voltage slightly drops during idle, I don't have a volt meter. I just know it's dropping, cause I can see my headlights slightly dimming. When I rev it up, the voltage seems normal. Anybody know what's causing this? Oh, by the way, I have a new battery in my car.
ThX
Old Mar 17, 2003 | 11:44 PM
Ekasey's Avatar
Default Re: Voltage slightly drops during idle (96RS)
do you have an aftermarket alternator pully this would be one reason also honda alternators aren't supposed to really charge at idle
Old Mar 18, 2003 | 12:03 AM
96RS's Avatar
Default Re: Voltage slightly drops during idle (eLusive ek4)
Actual, I do. So do you think this is the reason why the voltage is slightly dropping?
ThX
Old Mar 18, 2003 | 04:32 AM
JimBlake's Avatar
Underdrive pulleys make the alternator turn a bit slower than stock. So if Honda designed it to just barely keep up with the load at idle, then now at idle it will drop voltage. My GS-R does that with stock pulleys if I have the headlights & vent fan all turned on.
Most people spend plenty of time above 1000rpm to keep the battery charged. If all you ever do is idle, then you shouldn't use an underdrive pulley.
Old Mar 18, 2003 | 09:35 AM
96RS's Avatar
Default Re: Voltage slightly drops during idle (JimBlake)
[QUOTE]
I didn't know that about the honda alternator's.
I appreciate the info.
Much ThX!
Old Mar 18, 2003 | 10:52 AM
raene's Avatar
That's how they make power Less alternator spins = less drag on the engine.
Old Mar 18, 2003 | 11:46 AM
Farnsrocket's Avatar
Default Re: Voltage slightly drops during idle (raene)
I just replaced my Unorthodox alternator pulley with my stock one because my car was dying when I would roll the window down or open the sunroof. Idles way better now.
ZCHondaCRX91
Mar 31, 2011 02:54 PM
ludedude808
Nov 5, 2006 10:44 PM
PINKS
19
Jul 25, 2006 03:47 PM
integra90xsi
Apr 25, 2004 12:41 AM
hondura
Sep 24, 2001 08:23 AM
