Car boged today when hitting vtec....
Old Mar 17, 2003 | 10:44 PM
Frito1's Avatar
Default Car boged today when hitting vtec....
Today I was coming to the freeway onramp in third gear. As soon as I hit the vtec crossover point the engine would start to jump or bog. like it wanted to stall or something. So i did it a couple more times to make sure and everytime I tried to go above the vtec point, the car would bog. Whats going on?
Old Mar 17, 2003 | 10:46 PM
sa21199's Avatar
Default Re: Car boged today when hitting vtec.... (Frito1)
check your oil
Old Mar 17, 2003 | 11:58 PM
B2FiNiTY's Avatar
Check your spark plugs and wires.
Old Mar 18, 2003 | 05:55 AM
b19coupe's Avatar
Default Re: Car boged today when hitting vtec.... (sa21199)
check your oil
Old Mar 18, 2003 | 01:58 PM
Frito1's Avatar
Default Re: Car boged today when hitting vtec.... (b19coupe)
Thanks for the help!
I'll check that out before I drive again.
Old Mar 18, 2003 | 06:14 PM
1quik95gsr's Avatar
check your oil same thing happen to me, i had to add 3 quarts its was really low lucky that i didn't blow my engine
Old Mar 18, 2003 | 06:17 PM
P1mpSlap's Avatar
Default Re: Car boged today when hitting vtec.... (1quik95gsr)
same thing happened to me. Weird as ****. I think it seeped out through the cams seals or something.
I only had to add 2 quarts.
Old Mar 19, 2003 | 08:35 AM
Frito1's Avatar
Default Re: Car boged today when hitting vtec.... (P1mpSlap)
It was the oil. I had to add a quart and a half, so now my vtec engages, but now my engine light is on. I got to check that out now. The car runs now like it did before. Thanks for the help again.
Old Mar 19, 2003 | 08:43 AM
INTEGRAMIKE's Avatar
disconnect the battery and then reconnect it that will take care of the check engine light. Vtec shuts down when you are low on oil as a saftey precaution. Most of the time it will happen going through a turn. Dont let it be a warning sign that you need oil, you should check your oil every morning in your gsr to be sure and safe. It might be overkill but its better than a blown motor, trust me I know.
Old Mar 19, 2003 | 08:49 AM
opi's Avatar
opi
My car was doing the same thing last week...of course, check the oil like the other members suggested...at the same time, you might wanna check your vtec solonoid gasket. I picked one up at the dealer for about 17 bucks...just a suggestion
Old Mar 19, 2003 | 08:59 AM
NeoGSR's Avatar
2 quarts is way too low, 3 quarts is just insane.....the gsr only holds about 4.25 quarts anyway.....if i ever ran that low on oil i'd sell my car and buy a bike....scary
typeR564
Apr 23, 2006 05:10 PM
cioli
Jul 6, 2005 03:05 AM
DMF
Feb 3, 2003 05:43 PM
SleepinAround
Sep 8, 2002 12:04 PM
People_Mover
Aug 1, 2002 04:19 AM
